A new project found the way to me: DT360
- Gerryz
A new project found the way to me: DT360 was created by Gerryz
Hi there! I‘m very happy to tell you that a DT 360 in bad condition found the way to my workshop
It‘s an US Import and there are some parts missing. This nice forum here gave me all the necessary documents to do my work…. Great download area!
If there is anybody out there who has parts and is willing to sell to Germany, I need: Front mud guard, reinforcement plate for the fork, heat protection grid for the exhaust pipe, all indicators.
Sure I need more help in the future
Gerry
Gerry
02 Mar 2024 11:22
Replied by Gr8uncleal on topic A new project found the way to me: DT360
Do you mean the fork brace?
Whilst I appreciate that yours is a US model with the high front mudguard, bear in mind that the Euro models came with the lower, fork mounted mudguard, as fitted to the DT/RT 1/2/3. If you go for this option, then a fork brace won't be needed (or fit!).
Rear indicators will be the same as fitted to the RD, XS etc and should be easy to source. However, the mounting brackets will be harder to find.
I am likely going to change to fork ear mounted front indicators on my own DT360A - again, as fitted to the road models. If I do, then I shall probably sell on my handlebar mounted ones. I am in the UK.
02 Mar 2024 11:54
- Gerryz
Replied by Gerryz on topic A new project found the way to me: DT360
Thanks for the information. I saw no fotos with the lower mudguard on a DT360. Thats the reason I‘m looking for brace and mudguard. If there is a better chance to get a low mudguard this will also be ok for me
I will wait and see…..
02 Mar 2024 12:52
- Sneezles61
Replied by Sneezles61 on topic A new project found the way to me: DT360
Best look at the lower fork tubes… are there holes drilled and tapped? If not, back to the high mounted fender.
02 Mar 2024 13:22
"Best look at the lower fork tubes… are there holes drilled and tapped? If not, back to the high mounted fender."
Good point.
Original parts will take the lower mounted fender - it's where the fork brace gets fitted on the models with the high fender.
Good point.
03 Mar 2024 00:00
