Oil tank draining into transmission?
- Superdad60
Oil tank draining into transmission? was created by Superdad60
Runs great
However:
When I park for 2 weeks all the oil in the tank ends up in the transmission
Then when start up, the transmission overflow pukes out combo oil as there is like 3 quarts in there. Checked oil pump side case and no oil
I thought the two were completely isolated and have beat my head on the wall trying to search and find out if anyone had the similar issue?
Thoughts? What am I missing?
Any expertise appreciated
Runs great
However:
Replied by MarkT on topic Oil tank draining into transmission?
Oil pump drive shaft seal in clutch cover is bad or missing.
#5 here www.partzilla.com/catalog/yamaha/motorcy...l-pump-250b-c-400b-c
15 Feb 2024 10:06
- Superdad60
Replied by Superdad60 on topic Oil tank draining into transmission?
Is that part number 5 on the diagram?
and thanks a mill Mark
15 Feb 2024 10:09
- Superdad60
Nevermind I see you wrote #5 Duh
15 Feb 2024 10:10
Yes, it presses into clutch cover from inside so cover needs to be removed to get to it.
15 Feb 2024 10:34
