Perfume on a Pig
  • Schu
  • Schu's Avatar Topic Author
Replied by Schu on topic Perfume on a Pig
Ok. I’m getting close. Whatever you call this little passageway at the bottom of the bowl was plugged. And after zooming in on this photo I think it may still be partially plugged even though I passed a guitar string thru it. I know I know you’re not supposed to use a wire to clear it out, but come on, this is a perfumed pig we are talking about here. I did confirm that all sizes are as per MarkTs list. And maybe I should order the larger jet he suggested.
imgur.com/a/l1s2CKE
Here are the results, and this time I clipped my phone to my jacket, albeit turned the wrong way and viewing nothing worth looking at! I am getting close. It still hesitates a little as I run thru the gears, but it is way better. Like I said, I think I can clean that passage out a little better.
31 Mar 2024 13:52 #11
Replied by MarkT on topic Perfume on a Pig
Definitely much better! (That's the starter jet.)
Check the passages from the pilot up into the throat of carb.
Other than that, a richer pilot will probably get rid of the remaining hesitation.
31 Mar 2024 14:29 #12
  • Schu
Thanks Mark. I will order both the 27.5 and 30 pilot jet sizes and see which one is best.
31 Mar 2024 15:08 #13
  • Schu
Still waiting for my larger jet from partzilla. It appears to be stranded or lost in Allen Park Michigan. So close, but yet so far......
12 Apr 2024 04:03 #14
Replied by Wrench66 on topic Perfume on a Pig
An easy check is to turn your mixture screw in a 1/2 turn or so and see. It will likely idle a little richer ..... I would also raise the slide needle one notch richer just to see again if that helps going through the gears. If you get a positive response from either or both of these tests then it's easier to focus on a proper fix.
Nothing makes me smile like the smell of Blendzall green label ;)
16 Apr 2024 16:08 #15
  • Schu
Thanks for the suggestions. Partzilla has dispatched another order assuming that the first order got lost. They expedited this order with 2-day air so hopefully I see it on Thursday. If not, I will give your suggestions a shot. Thanks again!
16 Apr 2024 17:03 #16
