Rear hub spacer orientation
- AirborneSilva
Rear hub spacer orientation was created by AirborneSilva
Hey guys, I'm getting ready to put new bearings in the hub so I can attempt to lace and true the rim but when I removed the old bearings I didn't see how the hub spacer and flange were orientated, it just fell out into the bucket I was using to keep the hub off the ground. the spacer has a hole in the middle with the flange to one side of the hole (hopefully that all makes sense), here's the page on Partzilla that shows the parts, they are 12, 13 on the diagram. Thanks guys!
Rear wheel diagram
Rear wheel diagram
01 Dec 2023 13:28
- Tinkicker
Replied by Tinkicker on topic Rear hub spacer orientation
Fear not. It does not matter. However I always knock out the bearings from the chain side first and orientate the flange away from me to give the best area of spacer to tap on.
On some bikes it does matter, the hub "tube" is bellied inwards not a straight forward parallel sided tube. Think it may be some hondas that do that.
The following user(s) Liked this Post: MarkT, AirborneSilva, nhsteve
- AirborneSilva
Replied by AirborneSilva on topic Rear hub spacer orientation
Thank you Tinkicker, that's the answer I needed and was hoping for! Have a great weekend!
02 Dec 2023 01:29
- Mothersbaugh
Replied by Mothersbaugh on topic Rear hub spacer orientation
Another reason the orientation is of little consequence: the purpose of that tube is for ease of alignment for the installation of the axle...
05 Dec 2023 15:32
- AirborneSilva
Thanks MB, got the hub together now trying to figure out the lacing part
06 Dec 2023 01:39
