Ignition side crank seal 74 dt360
- Rci-Resto
Ignition side crank seal 74 dt360 was created by Rci-Resto
Will a stator side crank seal cause pinging at low and steady rpm, planning on changing it tomorrow, already changed oil side. I'm sure it worn, hard to get a steady idle also
08 Oct 2023 18:29
Replied by RT325 on topic Ignition side crank seal 74 dt360
I don't really think so unless it's falling out in which case it'd affect total carburation.
Just my 2cents worth, but be interested to hear the outcome if changing that & not altering anything else.
Of course i've been wrong before--just can't remember when haha.
Probably yesterday!!.
Tighten that flywheel good & solid please.
08 Oct 2023 18:56
- turbodan
Replied by turbodan on topic Ignition side crank seal 74 dt360
Many crank seals have been replaced on these to no avail. If there is no oil passing through from the inside out I wouldn't be too eager to throw a new seal at it just yet.
The 74 360 is a difficult motor to get sorted out. Porting and head work help significantly as the stock squish clearance is terrible and the porting does a poor job of scavenging the cylinder.
09 Oct 2023 18:44
- Rci-Resto
Replied by Rci-Resto on topic Ignition side crank seal 74 dt360
My oil side pushed out and I replaced, read irratic idle due to ignition side failing,it's jetted good, just don't want damage from riding it
10 Oct 2023 03:54
