sudden timing issues?
  • Digger65
  • Digger65's Avatar Topic Author
Replied by Digger65 on topic sudden timing issues?
imgur.com/a/XcH4btM
ok cases apart without any more issues with bolts
think apart from bent shaft i may have got away "lucky"?
no apparent damage to gears which look in pretty ok condition
one bit floating about in there and a blown seal
20 Aug 2023 08:48 #101
  • Digger65
any chance of a link to the ebay part pls?
i cant seem to search or locate US parts from UK
J
20 Aug 2023 08:52 #102
Replied by MarkT on topic sudden timing issues?
Now that you have it out, have you checked to be sure it's bent?  With the bearing blown to bits, it might have been hard to tell.  (I know, wishful thinking...  but stranger things have happened.)
Almost certainly the damage was done with the kickstart from the looks of it so I'd check those three gears very carefully.
The following user(s) Liked this Post: Digger65, Ht1kid
20 Aug 2023 08:54 #103
  • Digger65
was thinking the same
have the new needle bearing, the kick and idle gear so could possibly offer up to see
or presume may have to take to bits to see if it is without gears on it
20 Aug 2023 09:10 #104
Replied by Ht1kid on topic sudden timing issues?
eBay item # 195599724735
20 Aug 2023 09:44 #105
  • 's Avatar
  • Visitor
  • Visitor
Replied by on topic sudden timing issues?
D&K have a complete DT175 gearbox on ebay for £74.
Taking into account shipping charges from the US, it might be cheaper to buy that, and sell what you don't need?
I have TY175 output shafts, but they are probably different to DT.
20 Aug 2023 09:47 #106
Again, 1976 is a unicorn.  If you have a 1976 DT175c (559 VIN prefix) many of the transmission parts are "one year only" in the USA.
Though 1976 and later Euro twin shock bikes (Euro "F" model, not related to the US model naming letter scheme) could be the same.
20 Aug 2023 10:13 #107
  • Digger65
shaft doesn't look quite so bad now new needle bearing offered up but still has a wobble i think whether that's it moving in the case or actually has a bend its hard to say
i will change out if i can find one
thanks for the links i will look at them now
one thing that is a problem is
imgur.com/a/eqV0zSa
some damage to the bearing housing, not cracked but the damage has deformed the housing
anyone have a good idea to pack it out?
JB weld or is that swearing on these forums?
have a few fabricators in area i could ask to do it i guess
20 Aug 2023 11:41 #108
  • 's Avatar
  • Visitor
  • Visitor
See how much material around the outside of the bearing housing, and see it if it would be possible to machine the housing bigger, and fit a sleeve with the same ID as bearing OD.
20 Aug 2023 12:05 #109
  • Digger65
yes thats a possibility
or find a crankcase replacement  i guess
D
Last edit: 20 Aug 2023 15:12 by Digger65.
20 Aug 2023 12:35 #110
