1974 DT250: Differences from DT1/2/3?
- patentgeek
1974 DT250: Differences from DT1/2/3? was created by patentgeek
I'm trying to identify the major differences between a 1974 DT250 and the earlier DT1/2/3 models. I've searched the forum, but haven't been very successful.
Are the engine cases and frame the same or different?
01 Jul 2023 23:30
- asco
Replied by asco on topic 1974 DT250: Differences from DT1/2/3?
There are several distinct differences.
power 74’ less hp
weight 74’ heavier
front fender 74’ high
74’ reed valve
74’ some are CDI ignition
the parts for the most part are not interchangeable
a
power 74’ less hp
weight 74’ heavier
74’ reed valve
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
01 Jul 2023 23:39
Replied by Gr8uncleal on topic 1974 DT250: Differences from DT1/2/3?
Yes, many differences.
If you want to look at specific shared parts, then clicking on a part on Partzilla or CMSNL will show which models used it.
02 Jul 2023 00:11
Replied by RT325 on topic 1974 DT250: Differences from DT1/2/3?
Different motor & different frame.
Essentially nothing the same except for piston kits that you could find listed in aftermarket sites as good for DT2&3 plus DT250 & so on.
Motor from "74 on is longer & mounts are different--& so it goes on.
"74 '250'was still points, all the way to "78 i think" then went CDI for the "79 last year & borrowing it off the DT400 which had used the same one for a couple of years.
Actually the points mag & cdi mag off all those models including DT400 will swap over onto DT1-2-3.
Sounds like you have a project, i like projects--what is yours?.
- patentgeek
Replied by patentgeek on topic 1974 DT250: Differences from DT1/2/3?
RT325, super helpful response.
I might be able to get a good deal on a local '74 DT250, but I was hoping it would be more similar to the DT1/2/3 models since I'm building up a Trackmaster with a DT2 engine.
02 Jul 2023 11:01
"74 is a good bike & good strong motor.
Lower frame too, but does it put you out of class? being "74.
02 Jul 2023 17:28
- patentgeek
Hmm, seems like somebody else said the '74 frame was taller?
I'm not racing. My first bike was an early 80's DT175 so thought I might add a two-stroke to the 30+ bikes in our garage while I'm building up the DT2 Trackmaster for my girlfriend.
02 Jul 2023 22:39
You could be right but i always thought the "74 looked like it was dragging its bum on the ground compared to earlier 250 & 360 models.
photos.app.goo.gl/U1zPEfBepKNkW8Vc6
03 Jul 2023 00:47
Replied by MarkT on topic 1974 DT250: Differences from DT1/2/3?
I agree RT325... I always thought the engine looked lower in the 74 on frame? If it was, I guess someone could say the "opening" from engine cradle to backbone in the frame was taller?
I think the 1974 Service manual in Tech Library has fairly detailed frame dimensions near the back? Not sure where to find them for older models.
03 Jul 2023 03:40
Probably the frame grew taller & lower taken from a point halfway up, so the exhaust could go over the motor & through the frame. Something like that.
03 Jul 2023 16:19
