1975 DT175 Crank O Ring part 93210-180A6-00
- jeffjeffjeff
1975 DT175 Crank O Ring part 93210-180A6-00 was created by jeffjeffjeff
When taking the right side crank parts out, there was not an o ring and this motorcycle was never disassembled. I know Partzilla is sometimes wrong with it's diagrams. Is this o ring placement correct? I don't have it ordered yet but it just seems like it would get sandwiched between the collar and the bearing when tightened which doesn't make sense because it would get smooshed. Or perhaps it stretches on the outside of the collar which would not seem to provide any function then.
Photos don't seem to be uploading. Hopefully this link works:
photos.app.goo.gl/iV6u3FRhAT59ev779
Thanks,
Jeff
Thanks,
Jeff
08 Jun 2023 15:14
Replied by RT325 on topic 1975 DT175 Crank O Ring part 93210-180A6-00
Fits in the groove Jeff as shown in the ebay crank number here. Does yours not have a groove. Spacer just pushes over it with tension--in theory anyway.
eBay item number:164814862861
- Visitor
Replied by on topic 1975 DT175 Crank O Ring part 93210-180A6-00
O ring fits into a groove in the crank, and the primary gear sleeve slides on over it. CSMNL is the best place for parts diagrams.
08 Jun 2023 15:31
- jeffjeffjeff
Replied by jeffjeffjeff on topic 1975 DT175 Crank O Ring part 93210-180A6-00
Of course. Didn't see that. Makes perfect sense now. Thanks!
08 Jun 2023 16:36
- Schu
Replied by Schu on topic 1975 DT175 Crank O Ring part 93210-180A6-00
My CT1B had me thinking something was wrong because the sleeve didn’t want to go over the Oring, but it simply took more force than I expected.
youtube.com/shorts/itne0Kjg1fE?feature=share
08 Jun 2023 16:55
- Visitor
You should not need any force to fit the sleeve if the correct oring has been supplied. Many sell orings which are not correct (too big), which will be damaged, when the sleeve is forced on.
08 Jun 2023 23:12
- Sneezles61
Replied by Sneezles61 on topic 1975 DT175 Crank O Ring part 93210-180A6-00
Mr. Schu, can that sleeve be flipped over 180 degrees?
Sneezles61
Sneezles61
09 Jun 2023 04:52
- Schu
It's long since been assembled. Like I said, it just took more force than I assumed it would. And maybe I did get an oring that was oversized. But I've been rolling for a long time since this happened, so life is good.
10 Jun 2023 15:15
