Dt250a timing
Replied by MarkT on topic Dt250a timing
Light should dim when points open.
24 May 2023 19:07 #11
  • Jewelkutter
  • Jewelkutter's Avatar Topic Author
Replied by Jewelkutter on topic Dt250a timing
Good Morning Everyone,
I did like you said Ht1kid, I put the light on and rotated the flywheel counter clockwise until tdc, then clockwise to 3.2 , the light was still bright so the I loosened the point screw and moved it one way and the other and i noticed the light go dim so i tightened up the screw , i looked down at the timing mark on the flywheel and noticed it was in line with the tang on the lighting coil , so to check , i turned the flywheel back to tdc and then turned it clockwise again to 3.2 and the light went dim and the mark on the flywheel and tang were in line. You guys really helped me out again. I appreciate it.
I've never done points ignition , on my old triumph bikes, I converted them all to electronic ingnitions so never learned points . Next thing I gotta do is figure out how to donate to the forum.
Thanks again you guys , hope you all have a great day.
John
The following user(s) Liked this Post: MarkT, Gr8uncleal, Ht1kid, Andy L
Last edit: 25 May 2023 04:57 by Jewelkutter. Reason: Misspelled word
25 May 2023 04:56 #12
Replied by Gr8uncleal on topic Dt250a timing
"Next thing I gotta do is figure out how to donate to the forum."
Good man!
See "Donate" box on the right of the screen.
The following user(s) Liked this Post: Jewelkutter
Last edit: 25 May 2023 05:03 by Gr8uncleal.
25 May 2023 05:02 #13
Replied by Ht1kid on topic Dt250a timing
Great news congrats.
25 May 2023 06:14 #14
  • Jewelkutter
Thanks GR8UNCLEAL, I made a donation
The following user(s) Liked this Post: Gr8uncleal, Ht1kid, Sneezles61
25 May 2023 06:43 #15
Replied by RT325 on topic Dt250a timing
That's great news, & top marks to HT1kid for clear instructions. Now--does it run!!.
Last edit: 25 May 2023 14:56 by RT325.
25 May 2023 14:56 #16
  • Jewelkutter
I know, all wicked clear instructions from all of you guys. haven't started it yet , been burning out the pipe today , tomorrow sandblast and paint it then I'll put the tanks on it , I'm getting close
John .
The following user(s) Liked this Post: MarkT, RT325, Ht1kid, Sneezles61
25 May 2023 15:40 #17
  • Jewelkutter
Hello Everyone,  I'm wondering about the headlight plug connections. In the picture my plug has 2 black female connectors .
From my harness into the headlight is a black triple connector , which is currently full,  im wondering about grounding my voltage regulator to one of the black female connectors on the headlight plug, or, should the ground from the regulator go into the triple black female connector from the main harness and the blacks from the Speedo & tach be plugged into the black female connectors on the headlight plug.
greatly appreciate all your help
john
28 May 2023 16:37 #18
  • Jewelkutter
Also, the male black bullet on the headlight plug , am I correct to assume it would plug into the black triple female from the main harness , essentially giving more places to plug in black grounds?
Thanks again
28 May 2023 16:41 #19
  • Jewelkutter
Oh ya, here's a peak at it
28 May 2023 16:55 #20
