1975 DT400 Oil Leak Help Needed
Replied by Ht1kid on topic 1975 DT400 Oil Leak Help Needed
Thanks MarkT
03 Jun 2023 09:19
#21
- Maxwell
Replied by Maxwell on topic 1975 DT400 Oil Leak Help Needed
I'll try to get a picture with a good angle to see how much space is available when the chain is on drive sprocket. When I feel around, there is about a finger width space (about a1/2 inch to 5/8 inch) between the shaft end and the drive sprocket
My plan, so far, is to JB Weld this pipe end cap to the casting where it's broke without getting JB Weld on the shaft end.
03 Jun 2023 10:04
#22
Sounds like a good plan
03 Jun 2023 11:55
#23
- Visitor
Replied by on topic 1975 DT400 Oil Leak Help Needed
If that's the end of the selector fork shaft that's visible, it seems as though the circlip locating the shaft is probably missing, there should be a 5-6mm gap at the end of the shaft to fit the rubber coated blanking plug?
Ideally the motor needs to be stripped, the missing clip replaced, and everything else checked at the same time?
What you have suggested might well work fine, but would be better if you can get an aluminium plug made, with a shoulder on the outside, to stop it going in too far, and provide a little more area to bond to.
