Wish me luck!
Replied by 1971DT250 on topic Wish me luck!
Sorry to see that. The hole might be too big. I have POR-15 in 2 of mine and they are still good after several years but the holes were smaller.
29 May 2023 12:02 #41
Replied by Ht1kid on topic Wish me luck!
What a bummer
29 May 2023 15:58 #42
Replied by RT325 on topic Wish me luck!
I'd clean it up around & out from the area then solder it with good flux & a very hot big soldering iron.
[Then go looking for a good tank online].
Was a fairly regular problem at work with older bikes especially farm bikes & was off down to the radiator shop & he had it sussed each time.
It'll be bad all along the bottom so no winners really just "get you by for a while methods" 'i think'.
The good thing is "it won't be visible under there,
Last edit: 29 May 2023 16:13 by RT325.
29 May 2023 16:11 #43
  • Schu
  • Schu's Avatar Topic Author
Replied by Schu on topic Wish me luck!
Ok, so now I'm a little nervous. Last time I rode it and noticed the tank leak,  it was running fine and then like a flip of a switch it started blubbering and running extremely rich. Smoking like crazy and wouldn't get past 4k on the tach to try and clear it out. So while I sort out my leaking tank, I will slip a misfit tank on it and try to figure out what happened. I'm hoping the fresh top end didn't catch a ring on the ports and break a ring. Maybe the nasty tank passed some debris, but it has a new petcock and a new inline filter, so not likely. I am running premix along with the autolube, but it ran perfect for about 20 minutes then instantly fell flat on its face sputtering and blubbering.
30 May 2023 13:48 #44
Schu how rusty was the inside of your tank?
30 May 2023 15:28 #45
  • Schu
It didn't look much worse than others I've cleaned up when looking thru the fill hole. But it must've been bad on the right side bottom surface. I did one 24 hour stint of evaporust along with multiple shake downs with strands of various size chain lengths for abrasives. A lot of loose flakes came out. That next ride was when I saw gas dripping onto the exhaust. I think my son has one of those bore scopes on a flex stem. That way I can get a good look at what I'm up against..
30 May 2023 15:45 #46
If it’s clean and you can get to the hole from the inside use some JB Weld tank repair
30 May 2023 15:48 #47
That's unusual--ran good then instantly went big smokey & blubbery. On the face of it it sounds like the right side crank seal did something--fell out--got damaged etc. That's unlikely.
So more likely you hit a bump & a lump of stray carbon got lodged in the spark arrestor in the tail muffler. Then you are using full throttle to get along at a low speed so more oil & fuel ==smoke & no power==constipation.
30 May 2023 16:07 #48
Replied by MarkT on topic Wish me luck!
Or float bowl o-ring failed?
30 May 2023 16:54 #49
Replied by Sneezles61 on topic Wish me luck!
Very fine rust “dust” and the filter won’t allow the desired amount of fuel thru?
Sneezles61
30 May 2023 18:54 #50
