1974 DT175 clutch questions
Replied by Swoop56 on topic 1974 DT175 clutch questions
A too heavy oil grade in the gearbox , can cause some clutch drag .
An inability to select neutral with the motor running , is a symptom of clutch drag .
Warped steels do the same thing , but I think you said earlier , they had been replaced .
05 Mar 2023 20:51 #21
  • dan
  • dan's Avatar Topic Author
Replied by dan on topic 1974 DT175 clutch questions
I will try a lighter oil, thanks.
Dan
dan
06 Mar 2023 04:15 #22
Replied by Tom P on topic 1974 DT175 clutch questions
I always shift into neutral as I'm coming to a stop, but if I am stopped and need to go into neutral, I just push the bike forward a bit as I'm easing the lever up.
The following user(s) Liked this Post: dan, Ht1kid
06 Mar 2023 08:05 #23
Replied by MarkT on topic 1974 DT175 clutch questions
Yamaha designed the transmission to shift into the next gear so like was said, a little clutch drag can make it difficult/impossible.
Also check and be sure the neutral spring and ball are present and in good condition. Parts #12 and #13 in the diagram here: www.partzilla.com/catalog/yamaha/motorcy...974/dt125a/shifter-1
Located right behind the neutral switch on top on case above the front sprocket.
06 Mar 2023 18:50 #24
