74 DT 360
  • Chitter
  • Chitter's Avatar Topic Author
74 DT 360 was created by Chitter
want to replace ignition with updated electronic one. What is everyones recomendations, Im in the US. been looking at VAPE or Rex Speed shop. Are there others I should consider.
15 Feb 2023 12:51 #1
Replied by turbodan on topic 74 DT 360
I went with Rex's and it's been great. Several thousand miles and no problems. I believe it is was less expensive than the VAPE system as well.
25 Feb 2023 06:31 #2
Replied by nhsteve on topic 74 DT 360
I was in a similar quandary a few years before either of those systems became available. I bought a used DT250A/B/C magneto assembly from a member here, had DEET refurb that, and mounted it up. Had to manufacture a jumper to make the 'kill' switch function I think, but then found a repro 250A harness so got that as well. But.... the thing is still only 6 volts. Not a huge issue for me. I can understand how having the system be 12 volts would be desirable though, especially in traffic.
My question for the systems mentioned is about the battery, but I have heard from some they have found a SLA battery that apparently fits that small battery box.
I'd probably go with REX's, but I'm in NH and so are they.
Last edit: 25 Feb 2023 07:39 by nhsteve. Reason: Information added
25 Feb 2023 07:39 #3
Replied by AirborneSilva on topic 74 DT 360
I went with Vape on my 76 DT400, great addition!
25 Feb 2023 11:29 #4
