DT175B crankcase breather
- Schu
DT175B crankcase breather was created by Schu
Ok, So if someone was dumb enough to have removed the plastic fitting and breather hose from the top of the crankcase, and then a few days later that same dumb person started cleaning the years of dirt and debris from the cylinder fins and various surrounding areas, only then to see the open hole that inevitably swallowed some filth……where would said filth end up? Just curious what would happen if someone was that stupid.
Let’s assume that it was a really filthy DT175B.
24 Jan 2023 17:13
Replied by MarkT on topic DT175B crankcase breather
There is a little "chamber" that the vent opens into... ultimately gunk could get into trans.
Depending on how much debris made it into vent, I'd probably prop engine upside down over a bucket and pour copious amounts of diesel fuel into trans drain plug and let drain out of vent hole.
24 Jan 2023 17:37
- Schu
Replied by Schu on topic DT175B crankcase breather
Thanks Mark. I swabbed down inside the vent hole with Q-tips and they bottom out in a short amount. The fuzzy tips brought up dirt for at least 6 swabs. I am going to do your suggestion for piece of mind. I’m still shaking my head…..
24 Jan 2023 17:57
It's probably not that bad at all.
Here's a link to an ebay set of cases so you can see the triangular chamber the vent fitting is in. There's basically a narrow slot between the case halves that vents trans to chamber to fitting.
ebay link
Light coat of oil or grease on q-tip might get most
ebay link
The following user(s) Liked this Post: JayB, Schu
24 Jan 2023 20:56
- Schu
Thanks for the link Mark. Now that I see the chamber area I think your suggestion of greased Q-tips would allow me to thoroughly clean it up. I’ll make sure I swab outward to avoid pushing anything thru the gap.
25 Jan 2023 14:26
Replied by RT325 on topic DT175B crankcase breather
Gears are pretty tough. They'll chew up anything thats not steel that fell down there. Come out in the next oil change.
25 Jan 2023 18:58
