DT360 - Red Wires Question
  • Jmckinney
  • Jmckinney's Avatar Topic Author
DT360 - Red Wires Question was created by Jmckinney
I have three red wires (labeled R1, R2, R3 in attached picture) coming from the rear of the loom.
Q1:  Should all 3 red wires have connectivity with each other?
Q2:  Which wire (R1, R2, R3) should connect directly to fuse?
Q3:  If the answer to Q2 is R1, how/where should R2 and R3 be attached/connected?
04 Jan 2023 11:09 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic DT360 - Red Wires Question
Pictures not working at the moment.
From memory, two of the wires have female connectors and one has male. Fuse holder sits between the two females and the male connects to the positive terminal on the battery.
The following user(s) Liked this Post: MarkT, RT325, Ht1kid, msavitt
04 Jan 2023 11:33 #2
Replied by msavitt on topic DT360 - Red Wires Question
glad to send over a picture jmckinney if its helpful
04 Jan 2023 14:37 #3
  • Jmckinney
Replied by Jmckinney on topic DT360 - Red Wires Question
Thanks for the reply!
See new attached pic/drawing...is that how you're describing?
04 Jan 2023 16:24 #4
  • Jmckinney
And please advise if my pics are not visible
04 Jan 2023 16:26 #5
Replied by AirborneSilva on topic DT360 - Red Wires Question
Pics are not visible, there's an issue with posting pics. If you want to post pics you have to use an image hosting site.
04 Jan 2023 16:40 #6
Replied by MarkT on topic DT360 - Red Wires Question
This has to be one of the most asked questions here.
No, all three reds do not have continuity with each other.  The male connector red (goes to battery) is simply a short wire wrapped in the harness.  The other end is one of the two female connectors. So there is continuity between male red and one of the female reds.
The other female red powers the bike.
Fuse holder connects between the two females.  See pic of factory fuse holder here:  www.partzilla.com/product/yamaha/55K-82150-01-00
It's genius in design...  if battery is disconnected from male harness connector, female connector on battery + protects battery from short.
Exposed male wire that plugs into battery is protected charges battery and could short if grounded with engine running...  but fuse would protect it.
In fact, every connection is protected from damage caused by short to ground if a connection comes apart (or is unplugged) by either a fuse or a female connector.
The following user(s) Liked this Post: Ht1kid, msavitt
04 Jan 2023 19:14 #7
  • Jmckinney
MarkT, can’t thank you enough…much appreciated.
05 Jan 2023 10:14 #8
