DT400 Running Issue
- Ride it like you stole it
Replied by Ride it like you stole it on topic DT400 Running Issue
Thanks guys hi all .. it was pilot jet pick up in float bowl
16 Aug 2024 05:25
#21
Won't let me reply properly so short msgs will have to do
16 Aug 2024 05:26
#22
Used a sewing needle wd40 & contact spray . I don't have a compressor
16 Aug 2024 05:29
#23
Exhaust is ok &I've not oiled the filter .. revs fine now carb just needs tweaking
16 Aug 2024 05:30
#24
Replied by RT325 on topic DT400 Running Issue
Not sure, but ya here now so must be doing right. Carry on & good to see you.
Sorry, i'm replying on the previous a page but it lands here!! i'm a page behind as usual lol. Great you sorted it & thanks for the update.
Might be just me but you say pilot jet pickup in the float bowl but do you mean the choke jet which is non removable down the cavity in the bowl. Easy to clean though but is a small hole. Clean under it too from side on where fuel goes under.
It must of been that one then
18 Aug 2024 09:06
#27
It's cast into the float bowl I thought it fed the pilot jet.
18 Aug 2024 09:08
#28
Only feeds the choke so will make no difference to running except to richen on closed or relatively closed throttle for starting. If you left the choke open, providing that jet isn't blocked it'll sort of richen above idle to I dunno maybe 1/3 throttle but if you say took it to full song or any revs then closed the throttle it will drown rich when you bring throttle up again until it clears. Damn it I do go on. Bottom line choke is only for cold starting & throttle needs be closed for it to suck from your "now blocked bowl jet". In saying that, if jet is blocked then opening the choke only makes a bad situation worse as only opens an airway which then leans off pretty much everything. Something like that haha.
- AirborneSilva
Replied by AirborneSilva on topic DT400 Running Issue
Go ahead and "go on" Morley, that's how people like me learn from you guys that have been there done that!
The following user(s) Liked this Post: MarkT, Snglsmkr, Sneezles61
18 Aug 2024 16:39
#30
