Sight Glass Leak 74 DT250
  • JWormy
  • JWormy's Avatar Topic Author
Sight Glass Leak 74 DT250 was created by JWormy
Hi All,
As I continue to piece this Frankenstein bike together, I got my auto lube pump tested, installed, and bled but after walking away from the bike for a while, I noticed the sight glass on the oil tank itself (which is from a '75 model donor bike) has a slow leak at the bottom of the rubber gasket. Replacements on CMSNL look to be about $53. Has anyone replaced this before? Is there an alternative O-ring or other type of gasket that can be replaced or doI have to get a replacement for the whole thing?
Also slowly leaking from the inlet nozzle on the pump hose even with a fresh new vinyl oil line. Thinking about adding an o-ring or some gasket sealer since the clamps I've tried don't seem to be doing the trick.
Any suggestions appreciated!
Jess
25 Oct 2022 10:55 #1
Replied by MarkT on topic Sight Glass Leak 74 DT250
Use Factory Yamaha oil line and clamps.
HVC Cycle might have a window kit at a better price? I don't know of any shortcut fix.
25 Oct 2022 11:31 #2
Replied by AirborneSilva on topic Sight Glass Leak 74 DT250
Here ya go...
sight glass
25 Oct 2022 13:39 #3
