12 volt conversion kits
Replied by Andy_C on topic 12 volt conversion kits
Off the top of my head I dont know what function the green wire carries out - you used to be able to download the fitting instructions form the Rex's website.
I will take a look at the wiring diagram and let you know.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
The following user(s) Liked this Post: chucklenutz
27 Oct 2022 12:34 #11
Replied by Bikes4Dan on topic 12 volt conversion kits
I know this is an old thread but it seemed like the best place to post.
I'm doing the electronic ignition / 12v upgrade from Rex's Speed Shop. I have purchased the essential ignition kit and had intended to purchase their 12v additional kit with lights/relays/horn/etc but it was out of stock.
The kit includes the ignition/charging stator, ignition coil, ignition module, voltage R/R
So, what I'm searching for is hopefully a compiled list of the following;
1. The various suitable 12v bulbs (LED might be nice but I can work from the incandescent numbers), including the headlight. I'm assuming a basic 5 3/4" sealed beam, hopefully for motorcycle use. I have an H4 headlight but not positive it will fit. There's a pretty good chance I will replace the stock turn signals with smaller units and store the ones I have, so that might solve itself.
2. Turn signal relay (3 pin or 4 pin?)
3. A suitable gel/solid state/maybe LiFe battery. I'd prefer not to go Lead Acid / AGM if possible. I really like LiFe but not sure the charging voltage will be up to the task.
4. For the horn I think I have a couple laying around.
I've searched a fair bit for a list and maybe it's buried in an build thread or ??? but I haven't found one yet.
The following user(s) Liked this Post: JGersh
24 Jul 2024 13:05 #12
Replied by pabdt on topic 12 volt conversion kits
I am testing this combo. was working on this today actually.
Sylvania 1141 for turn signals. (OReilly Auto Parts) (also, partzilla shows 12v bulbs in stock for DT125A)
Sylvania 1891 instruments. (though I think this bulb is a little taller than I want when finished)
LF1-S-PIN 2 Pin turn signal. (recommended by Makotosun in separate thread) amazon
Found a 5-3/4 on ebay for headlamp. Seems to work well, just need to make sure its snug too.
according to VAPE can use a 6 or 12v horn.
I'm a little concerned about the instrument bulbs producing too much heat high in the chamber, but I'm probably over thinking it. So far, this combo looks good as far as lighting. The LF1 was just too easy to install. I did end up cutting off connectors and putting my bullet connectors on.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 25 Jul 2024 01:31 by pabdt.
25 Jul 2024 00:45 #13
Thanks pabdt, that's a good start.
Post back how the instrument lights work out.
25 Jul 2024 16:51 #14
Replied by akara1 on topic 12 volt conversion kits
I have been using a small LIFEpo4 rc battery from hobbyking on my DT360a since i converted to 12v a few years ago and its been holding up great so far.
27 Jul 2024 21:09 #15
Replied by garyramir on topic 12 volt conversion kits
i agree and think your right about the instrument bulbs high heat.
gary
28 Jul 2024 15:57 #16
Replied by Wessi on topic 12 volt conversion kits
Dont know about the Rex conversion kit, but VAPE excludes a Li-battery in their manual.
No idea, why, but please check the Rex manual, if its allowed.
31 Jul 2024 05:06 #17
Can you post the specs or a link to that battery?
I've run LiPos in my R/C cars, they are a bit tempermental, I'd prefer a LiFe battery for the bike but your LiPo spec will be a good start.
31 Jul 2024 14:52 #18
I checked the Rex's installation instructions and it doesn't mention anything about the battery. I will ask them about the battery options directly.
31 Jul 2024 15:25 #19
Replied by Moto36 on topic 12 volt conversion kits
I went down the recently speedshop 12v route,I opted for the battery less capacitor.
27 Aug 2024 04:16 #20
