1975 DT100 gas cap
- yamahahaha
1975 DT100 gas cap was created by yamahahaha
Bike in question is a 1975 DT100. Problem is ignition switch is missing. NO KEY... Gas cap requires a key. Is there a key number on the gas cap??? I DO NOT have the bike in front of me...
- yamahahaha
Replied by yamahahaha on topic 1975 DT100 gas cap
I think I may have found my answer on FLEABAY. Shows gas cap with key number. Am I correct???????
21 Sep 2022 14:08
- AirborneSilva
Replied by AirborneSilva on topic 1975 DT100 gas cap
You can always take it to a locksmith, they can make a key for it.
21 Sep 2022 14:47
- yamahahaha
Hey Tony, ya but I'd like to see inside the tank before I even think about buying it
Ya I went on fleabay and saw a gas tank for same model. It had a number on gas cap lid. Not sure if that is 100% correct or not
- Lizeec
Replied by Lizeec on topic 1975 DT100 gas cap
I have the same bike, yes it has the key code on it as does the ignition and the seat/helmet latch, unless your gas cap or seat latch have been changed out the keys should match the lock on the gas cap and helmet/seat latch as well as the ignition and steering lock. Also another note I have been in your situation, it is usually the gas cap is just rusted to the tank, I’ve used large channel lock pliers with a rag around the cap and they usually come loose, very rarely did anybody actually lock the gas cap, I’ve had over a dozen DT250’s and DT400’s and I have never actually used the lock on the gas cap.
- yamahahaha
Thank you
21 Sep 2022 15:30
- AirborneSilva
Hi John, sorry I was thinking you actually had the tank. Yeah seeing inside would be very important, I've seen some pretty rusty tanks on ebay but the outside looked great.
21 Sep 2022 16:03
- yamahahaha
OK I bought the 1975 DT100. NO ignition switch like I stated earlier. Gas cap was not even locked just on tight. So back to the missing ignition. I'd like to try to get spark at least after I get the piston unstuck..
My question is " how do I hotwire it" for a lack of better words?
- yamahahaha
What is the white plug that is just out there for???
22 Sep 2022 16:44
- AirborneSilva
Hi John, glad you got the bike! There was a time, decades ago, when I knew how to "hot wire" a Yamaha 2 stroke but just can't remember how... I'm sure someone will know.
22 Sep 2022 16:46
