1974 DT125A won`t rev past 3grand
  • RT325
  • RT325's Avatar Topic Author
  • Platinum Member
  • Platinum Member
1974 DT125A won`t rev past 3grand was created by RT325
Page looks a bit strange so not sure what i'm meant to be answering but i'll go with the running fine the suddenly isn't. My first guess is something jumping around in the exhaust & got stuck in the spark arrestor or somewhere that's strangling the exhaust gases from escaping. Sorry if i'm lost in this post & replying wrong.
14 Sep 2022 05:17 #1
Replied by Yamadog1974 on topic 1974 DT125A won`t rev past 3grand
I Made a new post not sure why that other one thats old came up bikes only got 4000 mi on it. its possible and Ill check it out! Before it was running straight off the battery and ran fine till losing power......
14 Sep 2022 09:17 #2
Replied by MarkT on topic 1974 DT125A won`t rev past 3grand
Very confusing.  Why does title say won't rev past 3 grand?  But then you say it runs fine until battery runs low?
Problem solved right there.  You need a good battery for the 12v generator/starter model.  If battery runs low, it won't run right and then won't run at all.
Manuals in Tech Library have GREAT troubleshooting for the generator system.  Look at the earlier AT1 manuals too, sometimes they have more details.  Same wiring and operation was used from 1969-76 on the 125 generator/starter.
Just check maintenance (worn out brushes is common) and then follow the troubleshooting steps in order and you'll find the problem.
14 Sep 2022 09:40 #3
Mark it was running fine then it started running bad …. Was wired incorrectly, now that it is correctly wired I still have same problem… brushes are brand new and commutator was turned by me a machinist.
14 Sep 2022 16:02 #4
  • RT325
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic 1974 DT125A won`t rev past 3grand
Explain the Bad please. Just flat & no power or misfiring. Revs limited etc. Crank key compromised--not there or broken in place which woul give you a false inpression of timing if going by the marks. Are you holding the advance open to set it at 1.8 btdc. Sorry if its all been covered. I'm just thinking out loud.
Last edit: 14 Sep 2022 16:45 by RT325.
14 Sep 2022 16:43 #5
Yes to all your questions....... I`m thinking a bad condenser? I have a spare .It will not let you go past three grand immediately chokes out to the point of stalling but not quite. Even put a hot plug in it thinking plug was fouled,Because that`s how it runs ,like a fouled spark plug
15 Sep 2022 07:19 #6
So battery voltage is fine now when engine is running and revved to 3000?  Low battery is a common reason for ignition/misfiring issues on the 12v gen models as was indicated in your first (now deleted) post.
Last edit: 15 Sep 2022 07:30 by MarkT.
15 Sep 2022 07:30 #7
I checked battery with hydrometer all balls floated .... only rode the bike twice once after rewire and new reeds and again after hot plug install ,which i rode with lights on after dark..... Lights nice and bright!
15 Sep 2022 09:08 #8
If you have a condenser swap it.  Very easy on that model.
Sounded like problem started when it was wired incorrectly and battery was drained.   Now wiring is fixed and problem still there.  I'd be checking voltage with a voltmeter with engine running and revved up.You could have some kind of short when a relay kicks in or something.
15 Sep 2022 11:31 #9
Thank-You ,will update when I know more.
15 Sep 2022 11:37 #10
