DT 400 Carb Specs
- Andy_C
DT 400 Carb Specs was created by Andy_C
Can anyone tell me the definitive specs for a DT 400 Carb please.
I have looked in the workshop manual available from the tech section of this site, but they dont quite match what I have in my bike.
Thanks.
Thanks.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
10 Sep 2022 10:48
Replied by MarkT on topic DT 400 Carb Specs
What EXACT model do you have? Most data is for US models and there were slight variations between years (or even in the same year) sometimes.
Should also be a small stamp in carb body identifying the exact model. Might be about 5 digits and starting with "500" or "501"
10 Sep 2022 11:03
...Also, didn't you say it was running perfectly? Maybe the "don't quite match" variations are why?
You could post up what your carb has installed and maybe one of the 400 experts will know more.
10 Sep 2022 11:23
- Andy_C
Replied by Andy_C on topic DT 400 Carb Specs
Mark - perfectly fair comment.
All I was looking to do was "baseline" what I have in my carb against what it should be, it certainly runs very well, I am just interested to see what is different to the factory specs.
I'll dig out some more info, but for now all I can tell you it is a 1976 DT400 C USA Spec, I'll see what markings are on the carb.
10 Sep 2022 12:04
- JayB
Replied by JayB on topic DT 400 Carb Specs
I have a 76 DT400C US bike too. I tried to figure this out and got conflicting info from multiple sources. Here is a link to a picture of the spreadsheet I came up with. The right two columns are for the DT400C.
yamaha-enduros.com/index.php/forums/74-7...ecs-for-75-400#84545
I tried to include the picture but it didn't work.
- Andy_C
Jay - can see anything there.
I have taken a look at my carb and:
Body is stamped 500 63
Needle: 6F9
Clip: 4th groove from top
Slide: 3.0
Main Jet: B170
Pilot Jet: 6140
I have not taken the needle jet out.
As has been said the bike seems to run fine, all I was after was to compare my carb to the stock specification - managed to open your message that you sent the link to and it looks like my carb matches the spec that you have listed, given that I have not checked the needle jst or starte jet,
I think I can assume it is stock.
Needle: 6F9
Slide: 3.0
Main Jet: B170
Pilot Jet: 6140
Replied by Gr8uncleal on topic DT 400 Carb Specs
Just in case you haven't seen it, here is the spec shown on the Partzilla parts list.
Yamaha Motorcycle 1976 OEM Parts Diagram for CARBURETOR 400B - C | Partzilla.com
11 Sep 2022 00:34
- JayB
Andy_C: Sorry if the link didn't work for you. It works for me, maybe because I made that post. Your carb parts line up with what is in the spreadsheet I linked.
Great Uncle Al: Thanks for linking that. Partzilla was the only place I could find data on the DT400C carb and what I reference in the spread sheet.
11 Sep 2022 05:21
I think I have the Yamaha spec sheet for the 400C. I will look for it tonight.
11 Sep 2022 05:47
- Andy_C
Thanks Mark - really appreciate that.
11 Sep 2022 05:52
