74 DT250 Lighting Wiring
  • JWormy
  • JWormy's Avatar Topic Author
74 DT250 Lighting Wiring was created by JWormy
Hi everyone,
I recently replaced my stator with one from a '77 model which has two main difference from the '74. It incorporates a neutral switch and removes the wire for "daytime" lighting. Can someone explain to me how to properly use the one lighting wire from my new stator (yellow) and connect it to my light switch so that the lights just remain on at all times? Hoping this is possible rather than running a second wire from that coil somehow or is it easier just to replace the switch with one that doesn't include the lighting option. Also planning to just scrap the Neutral switch wire as my bike isn't compatible.
Thanks!
Jess
06 Sep 2022 18:32 #1
Replied by MarkT on topic 74 DT250 Lighting Wiring
First thing is you must run a regulator or you'll be blowing bulbs.  Later stators had more output and need regulators.  Follow instructions in Yamaha Service Bulletin and connect to blue feeding instrument illumination lights.
Other than that, you can simply connect yellow to yellow and single green to both greens.  Then just leave headlight switch on.  (if you turn headlight switch off battery will get a higher charge but should be okay...  I've done it.)
Or you can rewire bike and replace switches with parts from newer models so headlight is on all the time...  still must have regulator though.
06 Sep 2022 18:50 #2
  • JWormy
Replied by JWormy on topic 74 DT250 Lighting Wiring
Thanks, Mark! This was exactly what I needed.
07 Sep 2022 09:23 #3
  • JWormy
So I got the new stator installed and connected the wiring as you had mentioned previously. Was rooting through some of the parts that came with the bike and noticed a regulator. Looks to me like the p/o may tried to do the 6v-12v conversion kit from Rex's and that's what this regulator rectifier  is from. So is it safe to use this with the stator I installed and just used 12V battery instead of a 6V? Thanks!
24 Sep 2022 16:43 #4
