Annoying reed valve noise
Replied by MarkT on topic Annoying reed valve noise
Nice video!
I can't say I ever heard that exact noise...  could definitely be something vibrating as RT325 said.
30 Aug 2022 06:41 #11
If not exhaust maybe skid plate?
30 Aug 2022 07:24 #12
Replied by Ht1kid on topic Annoying reed valve noise
If you have a mechanic’s stethoscope start with the reed cage harbor freight has one for 5 bucks if not the redneck way is a long screwdriver against the cage and put your ear against the end of the screwdriver and observe the noise
30 Aug 2022 07:42 #13
Check your engine to frame bolts just another idea I would buy the scope(I have one) and idle it up to the noise and scope everything to find it
30 Aug 2022 08:48 #14
Replied by RT325 on topic Annoying reed valve noise
Had some strange noises to track down over the years but a common one was the front brake cable singing when forks are compressed & let up as cable slides against the guide on the lower triple clamp.
30 Aug 2022 14:17 #15
  • Wessi
  • Wessi's Avatar Topic Author
Replied by Wessi on topic Annoying reed valve noise
Thank you for your comments , apreciate all your input
Skid plate, cables and clutch arm are not vibrating, i checked already.
Also the crank seal doesn´t touch the flywheel.
I slightly hit with a hammer on the flywheel nut, while motor running. No change in the noise.
Will check the exhaust, i have a spare one.
Good idea with the scope, i will buy one.
I dont think thats something serious, but simply annoing.
30 Aug 2022 23:41 #16
