1975 DT250 Resistor
  • laup
  • laup's Avatar Topic Author
1975 DT250 Resistor was created by laup
hi all, i have a 75 DT250 and generally wiring ok but there is a resistor mounted between forks under front headlights with a black wire and a yellow and black stripe wire, cannot see anywhere in headlight cluster wiring where these are meant to go? any help welcomed,  (sits back and waits for the simple reply to make me look like a right muppet) thanks
17 Aug 2022 12:18 #1
Replied by Gr8uncleal on topic 1975 DT250 Resistor
 from Salisbury, UK.
Do you have a photo of it? Outside chance that it's an aftermarket voltage regulator, or one from a different marque (no problem either way).
17 Aug 2022 12:27 #2
  • laup
Replied by laup on topic 1975 DT250 Resistor
Thanks. Photo. Shows wires and mounting and black and yellow with black stripe wires, they were just pushed in to headlight cluster but no where to connect them in.
Last edit: 17 Aug 2022 12:52 by laup. Reason: detail
17 Aug 2022 12:37 #3
By sheer coincidence, I started a related thread a while back and I have attached a link to this.
I am no electrician, so cannot suggest how you might use this item - I would sell it on and buy a 6v regulator (assuming that it's still running 6v electrics).
Chrome exhaust?!
Yellow wire with black stripe - purpose and application - Vintage Enduro Discussions (yamaha-enduros.com)
17 Aug 2022 13:24 #4
Replied by RT325 on topic 1975 DT250 Resistor
By memory its to do with taking the place of the headlight bulb in one key position with engine running. Some scooters had that so you could whiz along on park lights or something but without headlight running.
The following user(s) Liked this Post: laup
17 Aug 2022 16:24 #5
  • laup
Thanks. Exhaust sounds great as well. Neighbours well happy with this project lol
18 Aug 2022 00:10 #6
Replied by Lizeec on topic 1975 DT250 Resistor
Would like to see more of that chrome exhaust pipe? Pictures?
18 Aug 2022 01:26 #7
  • laup
Not to everyone's liking I know.
18 Aug 2022 03:30 #8
Chrome gets damn hot--stick your leg to it. Be careful.
18 Aug 2022 16:58 #9
