76 dt400 regular
76 dt400 regular was created by Tomk
Where does the little silver box mount on a 76dt400 and has the one wire coming out of it
30 Jul 2022 17:43 #1
Replied by RT325 on topic 76 dt400 regular
Someone wil be along soon. But my undertanding is it belongs in with the yellow so saves the magneto powered bulbs & stops overcharging of the battery too. So if you have it mounted in original place on the bike [if it came with one--or this one] there should be a yellow close by. Others will know that model far better than me, even though i assembled them new & serviced them. But of course they never gave any trouble when new. Now they're coming back to bite us haha. I'm in NZ by the way & wiring differs on our in some ways but probably not in regards to the regulator. Your's might have a battery powered tail light where ours is part of the headlight circuit. Welcome if you're new!!. I'm just assuming your in the US. Cheers.
Last edit: 30 Jul 2022 17:51 by RT325.
30 Jul 2022 17:51 #2
Replied by Swoop56 on topic 76 dt400 regular
Silver box is your voltage regulator , for your headlight .
Your 75 service manual was probably of no help , as 76 was first year they were fitted as OEM .
My parts book shows it mounting to the chassis in the steering head area ,
between the High Tension coil and the Horn . I can't be more specific ,
as there are only arrows pointing to the vicinity of mounting position .
There should be mounting lugs or threaded holes there , so I'm sure you'll sort it out .
30 Jul 2022 17:55 #3
Replied by Tomk on topic 76 dt400 regular
Yeah there's a wire there it was hooked up I can hook it back up the problem was there was no airbox I put the airbox back in and now where they had it mounted is where the airbox mounts and I can't find any place there's a two bolt mount to match it in the book it shows it's up by the coil but that doesn't make any sense there's no amount
30 Jul 2022 18:15 #4
Is it mounted under the airbox itself with an earth wire to the regulator body as has to be earthed to work.
30 Jul 2022 18:41 #5
Replied by MarkT on topic 76 dt400 regular
My guess is you bought a used airbox?  I'm 99.9% sure it was mounted on airbox like RT325 said.
1975 airbox would be the same except for the regulator bracket.  1976 had the bracket.
Update:  Just found a pic of a 76 airbox on ebay and bracket is there so RT325 is correct.
The following user(s) Liked this Post: RT325, Swoop56, JayB, Snglsmkr
30 Jul 2022 19:08 #6
Replied by JayB on topic 76 dt400 regular
MarkT wrote: " Update:  Just found a pic of a 76 airbox on ebay and bracket is there so RT325 is correct. "
Thanks.  Now I know where mine goes when I get around to assembling my avatar!
30 Jul 2022 20:11 #7
Don't forget the earth wire if the filter box is plastic--well even if its not plastic considering possibilites for a bad earth mounted there.
30 Jul 2022 20:37 #8
Replied by Andy_C on topic 76 dt400 regular
I just replaced the 6v system on  my 400 with a 12 volt one - everyone is right about the position of the regulator being on that bracket on the air box.
One helpful tip, although there is an earth lead going to the unit, I recommend running another one from the engine - I used the decompressor bracket bolt to contact the engine to that earth point and then another to the ign coil.
Aparrently not having a earth lead to the engine causes a lot of electrical problems.
After I converted to 12 volts, the battery was being overcharged, fitting the engine earth lead as described fixed that - so guess if it affects the 12 volt conversion, it is worthwhile doing if you are still running 6 volts.
Just thought I would mention it.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
Last edit: 31 Jul 2022 05:28 by Andy_C.
31 Jul 2022 05:26 #9
