Rex's Speedshop conversion DT 400 - 1976
  • Andy_C
  • Andy_C's Avatar Topic Author
After taking the flywheel off my previousley running DT400 to clean out all the corrosion, it very quickly ceased to run, so rather than mess around trying to breathe life back into corroded components, even though cleaned up, I decided to fit a Rex's Speedshop ignition and 12v conversion.
It all arrived very quickly, instructions were easy to follow, and fitting easy.
The only "problems" I had was that one of the wires from the stator in the conversion was in the "wrong" place, so simply a case of changing it over (according to Rex's there are so many variants of wiring looms they dont always get it right), and the battery was being charged at 20 to 25 volts, easily fixed by adding an earth wire to the engine and then taking it to a common earth point - as recommended by Rex's.
After fitting the conversion it started 2nd kick, and first kick when hot, it idles perfectly, lights etc also work perfectly.
No sign of any kickbacks or difficult starting.
I have no relationship to Rex's speed shop, all I am saying is that from my experience if you are thinking of fitting one their kits, dont hesitate.
I'll probably put the old CDI on E-Bay as no point in hanging onto it.
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
The following user(s) Liked this Post: bike4fun, 87warrior
14 Jul 2022 10:29 #1
Replied by Buggin on topic Rex's Speedshop conversion DT 400 - 1976
Sounds great. Would you be interested in selling your original stator coil components? I am still crazy enough to try and keep my original ignition working.
1976 Dt400
1985 RZ500
2001 Xr650L
14 Jul 2022 11:20 #2
Replied by MarkT on topic Rex's Speedshop conversion DT 400 - 1976
Good to hear someone had a good experience with Rex!
We generally hear the complaints. and problems here.
Thanks for posting
14 Jul 2022 11:36 #3
Replied by DT-Steve985 on topic Rex's Speedshop conversion DT 400 - 1976
How much was the kit and have you got a link?
Mine feels like the timing has moved again as I’m losing top end revs and it’s not revving as freely.
14 Jul 2022 11:57 #4
  • Andy_C
Replied by Andy_C on topic Rex's Speedshop conversion DT 400 - 1976
Buggin - you are welcome to the stator / backplate and ignition sensor - the only thing missing is the source coil which I binned. Happy to send it to you for the price of postage. Are you in the UK?
15 Jul 2022 04:59 #5
  • Andy_C
Steve - just gogle Rex's speedshop all the info on prices / fitting etc can be found there.
The following user(s) Liked this Post: DT-Steve985
15 Jul 2022 05:00 #6
Hi Andy,
I am in the US. I can message my address to you.
Thanks,
Brett
1976 Dt400
1985 RZ500
2001 Xr650L
15 Jul 2022 06:26 #7
  • Andy_C
Brett - you have mail.......
15 Jul 2022 06:47 #8
