Clutch issues
- Turbotim
Replied by Turbotim on topic Clutch issues
So just basically clean all I can and put back together??
10 Jul 2022 09:55
#21
Replied by Ht1kid on topic Clutch issues
A manual impact driver should work on the screws with the correct bit and a lot of cuss words
10 Jul 2022 09:55
#22
Replied by Gr8uncleal on topic Clutch issues
Make sure that you use the correct JIS screwdriver bit, not Phillips - you'll be amazed at the difference that this makes.
10 Jul 2022 10:35
#23
Replied by MarkT on topic Clutch issues
Ignition point contacts are critical. If you had the Rx1 meter my guess is you'd see they are not making good contact.
10 Jul 2022 11:14
#24
- Turbotim
Is there timing marks on the flywheel and line it up
like you do on a cam belt on a car?? Or us there a
correct procedure to put the flywheel back on??
10 Jul 2022 12:40
#25
Manuals are in the Tech library. And lots of posts here on those topics. I'd start with manuals?
The following user(s) Liked this Post: Turbotim
10 Jul 2022 12:49
#26
