Points and condenser questions
- Turbotim
Points and condenser questions was created by Turbotim
Hi all
I've just serviced my oil pump so all good
im now doing the points and condenser
Picture 1 is the pully tool...picture 3 see many people
Taking the nut of will a impact socket...but I
don't have a cordless drill...how can I get this nut
Off with a drill and socket.... picture 2 are the new
point and condenser...do i need to check the gab of
Points or are the factory pre set?? Got parts from
Yam bits site....
Yam bits site....
Replied by MarkT on topic Points and condenser questions
Is there a good reason you're changing the points and condenser?
If not, I'd suggest leaving well enough alone. Original parts are very reliable and other than points sometimes needing the contacts cleaned, will normally last for decades and many thousands of miles.
Installing new points and condenser... "just because".., especially modern aftermarket parts... can often lead to trouble in my experience where none existed before.
This might just be my cheap lazy bastard side talking though.
02 Jul 2022 05:50
- Turbotim
Replied by Turbotim on topic Points and condenser questions
Im not sure if they need changing.... Im just
restoring the bike, ive changed so much its about
the only parts ive not done... il pop her back together
and see if she starting ok..
02 Jul 2022 06:05
