Clutch questions
Replied by Gr8uncleal on topic Clutch questions
"Im unsure the year of the bike as it had no log"
Apologies if you've done and posted on this already, but what is the engine number, specifically the first three characters?
Are the engine and frame numbers the same? It is often possible to fit an engine from one year into a frame from another.
19 Jun 2022 09:36
#51
- Turbotim
Replied by Turbotim on topic Clutch questions
So the frame number is different to the bike
sadly the original clutch basket was broken and
Had no disc of either solid or friction with it
I know the basket number as the original has
Both the numbers are the same on the original basket
and another one I brought.... Will measure the
plates and see what they are
19 Jun 2022 12:13
#52
If you post the engine number, then we can let you know what you have.
Edit - Apologies, I see that Mark has already mentioned that it is a 1976 model.
- Pete-RT1
Replied by Pete-RT1 on topic Clutch questions
Clutch friction plate part number is 559-16321-01.
Superseded by 36X-16321-00-00.
Either will suffice.
To check what year your frame is, use the VIN table in the Tech Library.
https://yamaha-enduros.com/index.php/175-cc-vin-numbers
Yamaha CT3 (in bits)
19 Jun 2022 13:36
#54
- Turbotim
Hi everyone through everyone help were getting there
I measured the friction plate and its 4mm and the steel
Plate is 1mm, am I correct in saying if I buy this part
number above it should fit??
cheers all
cheers all
20 Jun 2022 02:12
#55
- Turbotim
Hello all,
So when I brought the bike I was told it was 1975
So I brought 1975 clutch friction plates...
After everyone help which is very much appreciated
we found out its a 1976, i reordered the 1976
friction plates and it fits lovely...picture one is the 1976
Friction plate on the left and 1975 on the right...
Just random information for anyone the 1976
friction plates are alot smaller, im sure everyone else
Knows already....picture 2 and 3 is when its all fitted..
a massive thank you to everyone and will update on the bike
build if people interested...cheers all
The following user(s) Liked this Post: MarkT, AirborneSilva, Ht1kid, Pete-RT1, Sneezles61, Tom P
22 Jun 2022 07:32
#56
- Sneezles61
Replied by Sneezles61 on topic Clutch questions
I’d be disappointed if you didn’t keep us in the know.. (:
Sneezles61
Sneezles61
22 Jun 2022 12:49
#57
Replied by RT325 on topic Clutch questions
Wow what a difference, the difference we were looking for in fact. I guess thanks to MarkT & others that knew of the changes from "75 to "76. Learning curve for me in that respect too.
22 Jun 2022 13:59
#58
