Tyre advise
- DT-Steve985
Tyre advise was created by DT-Steve985
Good evening gurus.
does anyone know the correct size of tyre both front and rear for a 125a 1974?
many thanks
Steve
many thanks
Steve
23 May 2022 14:31
- Pete-RT1
Replied by Pete-RT1 on topic Tyre advise
Steve, I think originally you would have had a 3.00 19 front and a 3.25 18 rear, but that was as a 125.
Now you are a 175 you might want to go a bit chunkier.
175a would be 3.00 19 front (good luck finding that one) and 3.50 18 rear.
I'd recommend 3.25 19 Heidenhau K67 front I don't think they make a 3.50 18 rear. Kenda K262 is similar and is available as 3.50 18.
I have both of these tyres on my bikes and they are fine.
Yamaha CT3 (in bits)
23 May 2022 15:16
Replied by RT325 on topic Tyre advise
My old "70 AT1--125 has 18 both ends original. DT1 etc had 19 front original.
- DT-Steve985
Replied by DT-Steve985 on topic Tyre advise
Thank you for your help and advice
24 May 2022 01:28
- DT-Steve985
I have managed to find the following.
3.25x19 Heidenhau K67
3.50x18 Heidenhau K37
these sizes are quite difficult to find in the UK.
24 May 2022 03:20
- Pete-RT1
It's tricky with the sizes you have to make a pair of the same brand with the vintage block pattern.
The 3.50x18 Heidenhau K37 rear you found is a different tread pattern.
The Kenda K262 3.50 18 looks very similar to the Heidenhau K67 but is obviously a different brand.
The K262 comes in a 2.75 19 which may be a solution, but hard to find in stock.
24 May 2022 05:38
- DT-Steve985
Well great news, I’ve managed to find the tyres that Pete recommended, both in stock from a dealer and delivered for £140.00 ($175.50)
Front: 3.25 Heidenhau K67
Rear: 3.50 x 18 Kenda K262
24 May 2022 13:33
