Rear Sprocket
  • srsnow
  • srsnow's Avatar Topic Author
Rear Sprocket was created by srsnow
I am trying to replace the rear sprocket on my 125, I am using the parts unlimited one, as that was all I could find. I feel like I am missing something since it won't tighten down, it is loose. Has anyone run across this?
19 May 2022 16:29 #1
Replied by Gr8uncleal on topic Rear Sprocket
Have you fitted the large circlip as well as the bolts?
Is the sprocket loose on the hub, or the hub loose on the wheel?
20 May 2022 00:09 #2
Replied by RT325 on topic Rear Sprocket
We love pics. Just gives us a good insight as to what problem you've run up against. Did the old one lift over the big circlid & this one doesn't. Need circlip off as overlaps the sprocket. When bolted up the refit ciclip. Or are you talking something very different. Not new bolts way too long & going right through out the back of the cush drive & pushing on the hub. Na doubt that. 25 circlip holds 24 sprocket carrier on to the wheel.
www.partzilla.com/catalog/yamaha/motorcy...74/dt125a/rear-wheel
Last edit: 20 May 2022 19:04 by RT325.
20 May 2022 00:23 #3
20 May 2022 00:27 #4
  • srsnow
Replied by srsnow on topic Rear Sprocket
The old one came off no problem I just bent the locking tabs back pulled the bolts off and it came right off, is that normal?
20 May 2022 08:25 #5
What about the large circlip? Is it present, or is the groove empty?
20 May 2022 08:45 #6
  • srsnow
The clip is there, looking closer at it it look like the sprocket is tight on the hub but the hub is where the movement is. Is that normal?
20 May 2022 16:16 #7
Are you talking cush drive movement & wear on the hub plus cush unit--call it sprocket carrier. That's how they go once worn & flop around a bit. Doesn't pay to pack behind the circlip as loads it up with the sprocket moving the sprocket carrier around & just puts unwanted strain & wear on the circlip. Ok, might be ok with one thin washer if you can find one that big but--!! Video of movement would be great if possible sometime.
20 May 2022 19:12 #8
Replied by Tom P on topic Rear Sprocket
My sprocket moves a little bit, don't these have a cush drive?
20 May 2022 19:21 #9
Replied by Sneezles61 on topic Rear Sprocket
I just replaced my rear sprocket… I did have to remove a circlip to pull it off… I looked at the Cush/rubbers and they still looked new… so… on with the new one, replace the clip and snug up the bolts and bent the tabs… there is a wee of play…
Sneezles61
21 May 2022 07:05 #10
