Pop, bang, splutter
Replied by Gr8uncleal on topic Pop, bang, splutter
Check the air filter as well. Probably not the cause of the popping etc, but a blocked one might make the bike feel "strangled".
17 May 2022 10:19
#11
While you have the carb off, make a note of the number stamped on it. Also, if possible, check the jet sizes, the needle number and that these parts have the Mikuni logo stamped on them (a small square in the corner of a larger square). Don't be tempted to buy an aftermarket carb repair kit.
17 May 2022 10:24
#12
- DT-Steve985
Replied by DT-Steve985 on topic Pop, bang, splutter
It’s currently running an aftermarket performance filter but I’m looking to try and find the original air box.
I wouldn’t buy cheap copies, the bike is staying for a long while therefore it only has oem parts.
17 May 2022 11:25
#13
- Pete-RT1
Replied by Pete-RT1 on topic Pop, bang, splutter
Your carb looks like the original from DT125a, worth checking the jetting to see if they changed it from 140 main and 25 pilot to the CT1-B spec of 150 main and 30 pilot.
There is an o-ring (item 5 on the attached Diagram) which is critical to how your bike runs, Yamaha part no.214-14147-00 (standard o-ring size 007) I use the standard 007 in Viton.
The non standard filter probably effects the jetting too.
Yamaha CT3 (in bits)
17 May 2022 12:02
#14
- DT-Steve985
Pete thank you.
17 May 2022 12:27
#15
- DT-Steve985
Well I stripped the carb, all seemed ok, however the main jet looked To be 150 and the pilot jet 25 therefore a mix.
I then went on and pulled the points cover and took the pics below, also there was a piece of what looks like plastic in the housing, has anyone got any idea what it is?
18 May 2022 10:04
#16
Looks like the right part for that engine.
Can you pull the flywheel and see if the insides are intact?
18 May 2022 11:15
#17
- DT-Steve985
@gr8unclel I would have thought that if it had deteriorated inside the flywheel it wouldn’t run at all?
18 May 2022 11:21
#18
- Lizeec
Replied by Lizeec on topic Pop, bang, splutter
Looks like a very old packet of dielectric grease, like those little packs you get for automotive light bulbs or for ignition points rubbing blocks, is there any greasy stuff in that packet?
- DT-Steve985
It looks like a piece of hard plastic with some old gasket sealer around it.
