Piston
- Robabob
Piston was created by Robabob
Good afternoon
I am looking for a standard piston kit for a 1974 dt125a with not much luck, I ordered 1 from a w motorcycles but the piston is slightly longer, Any where else I find is out of stock. I am based in the UK so pref one that is already in the UK but not against have one imported if it is right. I was also wondering if the was other models that used the same piston
Rob
Rob
01 May 2022 04:44
Replied by RT325 on topic Piston
I'm no help sorry but what you likely ended up with is one from am RX125 if flat topped or an RS125 if dome topped. They're quite a bit taller & the cylinder is about one fin taller.
Try this number. i can't get the link to work [just me i think]. Go to the pic showing height measurements & this one shows 27mm to the top. The RS piston was 32.5mm measured the same way i think!! This is a Std 56mm DT125MX piston kit but i;m guessing its similar enough. MX isn't a motocross bike in this case.
eBay item number:
403625558641
eBay item number:
403625558641
Replied by Gr8uncleal on topic Piston
CMSNL have pistons in stock, but not all piston rings.
If you do buy from them, check to see if there is anything else that you need, so that you get max value out of postage cost.
Enduronut on this site might be able to supply what you need, but postage from the US might be higher.
01 May 2022 07:21
- Robabob
Replied by Robabob on topic Piston
Thank you for your reply. The measurements on that piston match the piston I have that doesn't fit. my piston has a slightly domed top and measure 22mm from the top edge to the edge of the pin hole and is about 63mm from top to bottom and would be a bit taller inc the dome. My original piston is on the right in the attached pictures.
Rob
Rob
01 May 2022 07:23
- Pete-RT1
Replied by Pete-RT1 on topic Piston
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=144466579839&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Robabob
Thank you all f
or your help we went with that piston and a set of rings of ebay and all new gaskets and it started 12 kick, have no idea when it was last started.
07 May 2022 13:02
Was that the link i put up in post #3, just wondering. Nice to know what works.
403625558641
403625558641
- Snowman212
Replied by Snowman212 on topic Piston
No it was the bare piston that Pete-RT1 suggested
