1974 DT250 Voltage Conversion
Replied by TheBeardedOne on topic 1974 DT250 Voltage Conversion
It looks like it's time for a new coil unless you're one of those people who enjoys trying to wind new wire onto the old core (not me!)
Were those bolts holding the coil on backed out like that when you pulled the flywheel? That could very well be your problem. If you have to redo the entire wiring harness anyway, I'd strongly considering upgrading to an aftermarket CDI. I've had good luck with HPI. The 60W lighting coil is a bit anemic, but probably fine for a bike that won't see the road often. There are other options (Rex's, Powerdynamo), but the HPI is probably the cheaper option if you don't have a factory harness to use the Rex's cdi. All three come with 12V lighting coils. Alternately, you could probably find a used 6v coil since so many people upgrade to 12V.
If you decide to keep the bike, I'd 100% recommend the powerdynamo for amazing lighting, but it's probably not in the budget for a bike you're just going to sell.
01 Jun 2022 12:53 #11
  • JWormy
  • JWormy's Avatar Topic Author
Replied by JWormy on topic 1974 DT250 Voltage Conversion
So I ran some resistance tests. The charging coil is good, but the ignition coil and lighting coils are both out of spec. Going to replace the ignition coil as they are relatively inexpensive, but I'm going to try to repair the lighting coil unless anyone knows of a replacement that doesn't break the bank. Trying to stay as close to stock as possible instead of upgrading to a CDI or 12V coils. I couldn't believe how filthy the flywheel/magneto was once I took it apart. I would guess the previous owner took the flywheel cover off and then rode through a swap. Completely caked in mud, rocks, grease, you name it. Two of the magnets were actually shattered into pieces.
07 Jun 2022 18:09 #12
