'75 DT400 engine overheating?
Replied by AirborneSilva on topic '75 DT400 engine overheating?
Can you post a picture of where/how you have it mounted?  I bought one for my DT400 but can't decide how to mount it.  Thanks!
26 Jan 2025 11:29 #11
Replied by DEET on topic '75 DT400 engine overheating?
A little trick I used during high engine temperature events was to depress the choke/enricher lever on the carb.
It basically throws raw gas into the cylinder which would TEMPORARILY cool the piston/cylinder. Of course, it ran poorly being that rich.
So any attempt at running cooler by changing the mixture or timing will have a trade-off in reduced performance.
The engine was designed to air-cool itself under certain parameter/conditions.
If you want to exceed those conditions but maintain high performance, other non-mixture/timing methods may be helpful.
Some ideas:
  • a larger fin area. Increasing fin area (Webco head) could help.
  • Fin extensions
  • Mechanical cooling (external fan- like what is used on a radiator)
  • Heat shielding for exhaust
Something else that may make a difference (I don't know if it would be good or bad) is the type of fuel used.
Octane?
% of ethanol?
Just some thoughts... I'm not an expert on anything, just my opinions...
I also use the Trail Tech.
The temperature sensor looks like a washer with a wire attached and mounts to whatever will fit through the hole (head bolt, spark plug, screw)
Mine also includes an input for speed and rpm.
The following user(s) Liked this Post: RT325, Snglsmkr, AirborneSilva, Ht1kid
Last edit: 27 Jan 2025 10:08 by DEET.
27 Jan 2025 10:00 #12
