wiring harness
- manchester
wiring harness was created by manchester
Last October I picked up two 1975 DT250's along with a bunch of new parts. I've spent the last couple of months cleaning, repairing and replacing parts on the better of the two bikes. I am now about 90% done with the final assembly but could use some good pictures of the wiring harness routing especially the area under the tank and along the upper frame. Both of these bikes had been previously molested so I don't have a good reference point. Any info you guys might have will be greatly appreciated.
Thanks, Scott
Thanks, Scott
25 Mar 2022 07:32
Replied by Gr8uncleal on topic wiring harness
Check out the Tech Library on this forum (see top toolbar) for a service manual for your bike. If there is one there, then at the very end of it should be a cable and wiring routing diagram. Post again if you're still having issues.
25 Mar 2022 08:33
Replied by MarkT on topic wiring harness
Service manual in Tech Library has pretty good routing diagrams.
25 Mar 2022 08:34
- manchester
Replied by manchester on topic wiring harness
Ok thanks. I'll have another look, hopefully I missed it
25 Mar 2022 09:03
25 Mar 2022 09:18
- manchester
Ok I found the info at the back of the service manual. Although that information will help me with some of the routing and clamp placement I guess I was hoping that someone had some actually photos. I have the majority of the harness in place but I am not exactly sure about the location of things such as how the larger protective boot that covers the connectors is secured under the tank -
thanks again for all the help
25 Mar 2022 11:07
- goatboy56
Replied by goatboy56 on topic wiring harness
This is how mine came so not sure if it will help as there was an aftermarket key switch spliced in.
John
John
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
25 Mar 2022 12:13
- manchester
Definitely helps with some of my questions. Thats the kind of stuff I am looking for.
thanks tons!
thanks tons!
25 Mar 2022 12:19
- Schu
Replied by Schu on topic wiring harness
Here's a few more. Not sure if they are clear enough. For some reason my photos that view perfectly clear end up very grainy and fuzzy once posted.
25 Mar 2022 15:29
- manchester
With looking at the back pages of the service manual and the pictures provided I think I have this figured out. Thanks to everybody for the help.
Hopefully in the next couple weeks I will have a smoke show! Exhaust, not wiring
26 Mar 2022 03:06
