DT 175A Piston
- DT2XC
DT 175A Piston was created by DT2XC
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=133896283776&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic DT 175A Piston
Stay away! There is a post from Enduronut on the topic... someone used one and it quickly failed and did a lot of damage in the process.
You can slightly modify Yamaha Blaster pistons to work... just file a little off the skirt length. Quality ones are available fairly reasonably priced.
The following user(s) Liked this Post: akara1
04 Feb 2022 12:00
- akara1
Replied by akara1 on topic DT 175A Piston
Chinese ones are a waste of time. don't even try.
if you want to cheap out, a modified Blaster piston from a name brand like Mark suggested works reliabily. Sometimes Pro-X blaster pistons are on eBay for 50-60$ and they come with rings and a good wrist pin
04 Feb 2022 13:00
- DT2XC
Replied by DT2XC on topic DT 175A Piston
Thanks for the feedback.
Fact is, I'm not sure I know what a Blaster is!
When I do a search...is there a year? engine size? etc?
Is this what I'm looking for?
Pro X 01.2281.000, 66mm bore
Ebay listing: 144036634658
Yamaha Blaster ATV Quad... made from about 88 into the 2000's... the engine is a direct descendant of your 175...
04 Feb 2022 19:00
