DT400 any difference between 75 76?
- Buggin
DT400 any difference between 75 76? was created by Buggin
Hello,
Picked up a 75 or 76 DT400 that has been sitting a long time. Started cleaning it up and surprise, no VIN numbers! Going to try and straighten it out with the authorities but in the mean time is there any known difference or markings besides the VINs? Hoping to save this one from the crusher, bike is otherwise complete.
1976 Dt400
1985 RZ500
2001 Xr650L
1985 RZ500
2001 Xr650L
17 Dec 2021 21:36
- msavitt
Replied by msavitt on topic DT400 any difference between 75 76?
www.justice.gov/archives/jm/criminal-res...entification-numbers
hypothetically speaking, it might be more advantageous to educate seller and get my cash back vs putting the heat on them and getting zilch
17 Dec 2021 21:42
- Bigdog302
Replied by Bigdog302 on topic DT400 any difference between 75 76?
other than graphics differences I don't know but others here may know beyond what I have mentioned. here is some pics of a 1975 and 1976 DT400.
1975 model.
1976 model.
1975 model.
1976 model.
Dave
Jesus is Lord!
Dave
Jesus is Lord!
Replied by MarkT on topic DT400 any difference between 75 76?
76 had a factory installed voltage regulator... slightly different lighting coil setup.
Carb was slightly different so probably has a different number stamped into it.
Easiest to spot are graphics... especially 76 only saying "enduro" on oil tank and heat shield
17 Dec 2021 22:35
- Buggin
Replied by Buggin on topic DT400 any difference between 75 76?
Ok then it must be a 76 because it has the "Enduro" only text on the oil tank and heat shield. Thank you for the info.
1976 Dt400
1985 RZ500
2001 Xr650L
1985 RZ500
2001 Xr650L
17 Dec 2021 23:17
- hatrick1960
Replied by hatrick1960 on topic DT400 any difference between 75 76?
Rear indicator brackets - Chrome on a 75, Black on a 76
The following user(s) Liked this Post: MarkT, Bigdog302
18 Dec 2021 01:07
- chuckw
Replied by chuckw on topic DT400 any difference between 75 76?
I also found some hardware differences, the bolts on the fork. Chrome 13mm on the 75, un-chromed 12 mm heads on the 76. Plastic formed bracket for the tach/speedo/key switch on the 76, steel on the 75. Slight differences in the headlamp mount hardware, the rings that hold them around the fork tubes and between the triple clamps.
69 DT1, 75 DT400 (2), 86 XT600, 78 Honda XR50, several 70's/80's MX bikes, 2021 Husky FE350
18 Dec 2021 18:30
- JimmyC
Replied by JimmyC on topic DT400 any difference between 75 76?
Here's a video of my 1976 DT400. It was bought new by my cousin and is all original besides mirrors, plastic plugs in mirror mounting holes and tires ( I replaced front tire after this video). It came with the 250 stickers on the tank (thats why he bought it). Has 1261 miles on it now.
The following user(s) Liked this Post: Bigdog302, SKYDANCER46, Schu, Sneezles61
- Sneezles61
Replied by Sneezles61 on topic DT400 any difference between 75 76?
I like the way the Cardinal is whistling at yer bike..
Do the mirrors perform well like that? I've not seen that way of mounting..
Sneezles61
Sneezles61
19 Dec 2021 06:19
- Pedalcrazy
Replied by Pedalcrazy on topic DT400 any difference between 75 76?
Beautiful bike but what’s up with the tank??? The graphics are for a 75 250 but tank for a 250 should be red. I didn’t look to see if you are overseas. Maybe UK bike IDK. If it had the 76 graphics for a 400 then wow jackpot!
19 Dec 2021 07:17
