DT400 twin shock - crankcase bolts
- Jammyyammy
DT400 twin shock - crankcase bolts was created by Jammyyammy
Hi all - I can’t see a specific torque for the 14 bolts holding the two crankcase halves together in the service manual, so I assume it’s just the generic torque setting using the attached table?
Is that correct? Thanks
23 Oct 2021 08:17
Replied by MarkT on topic DT400 twin shock - crankcase bolts
I have never attempted to torque case screws... just do my best to tighten them down evenly in stages a little at a time, until they are "tight" by hand with a JIS #3 driver.
I do have an inch-lb screwdriver-type torque wrench... might have to try that sometime. Not sure what the spec would be... let me see if some of the later manuals have something.
23 Oct 2021 12:33
The spec I found in a couple of 1980's manuals was 8 Nm or 5.8 Ft-lb specifically for two stroke 6mm diameter case screws.
Other manuals (YZ/IT) from the 1980's listed 12 Nm or 8 ft-lb
The generic manual spec you have says 10 Nm or 7 ft-lb which is in between so I'd probably use that.
23 Oct 2021 12:50
