1983 ag175 seal replacement
  • Izaac
  • Izaac's Avatar Topic Author
1983 ag175 seal replacement was created by Izaac
Hi all Iv got to replace the clutch push rod seal on my 83 ag175 "grasshopper" IV ordered a flywheel puller is it simple to remove the left side cover? Remove flywheel and shift lever and then bolts? Is it a "dry Cover" as in no gasket this single cover goes over the front sprocket as well.
21 Oct 2021 19:01 #1
Replied by MarkT on topic 1983 ag175 seal replacement
You shouldn't need to pull the flywheel to change a clutch pushrod seal.
Just remove the cover...  We didn't have that model here but pretty sure it's the same as our CT...  clutch cable goes into the side cover?
21 Oct 2021 20:07 #2
  • Izaac
Replied by Izaac on topic 1983 ag175 seal replacement
Yeah cable goes into the cover... But don't think I can get the bolts out with the cover on. The same cover goes over the rear sprocket as well I'll have another look
21 Oct 2021 20:51 #3
A picture would help a lot.
On that engine type you need to remove the cover...  there may be a cover over the flywheel and then the main cover over the sprocket.
Both covers come off without touching the flywheel.  If you are seeing screws behind the flywheel or down inside the cover, DO NOT REMOVE THEM.  They hold the center cases together.
Diagram of earlier US model should be helpful. You only need to remove parts 1 and 2 in the diagram here:  www.partzilla.com/catalog/yamaha/motorcy.../ct3/crankcase-cover
21 Oct 2021 21:10 #4
  • Izaac
Thanks I feel like a fool just had a closer look
21 Oct 2021 21:20 #5
  • Izaac
Thanks but one more question is there a way to keep mud out of the front sproket area
21 Oct 2021 21:24 #6
Replied by RT325 on topic 1983 ag175 seal replacement
This parts link might be good to look through. Hit the Diagram button up there to change the pic. The Grasshopper never changed much if at all through its years--good bike too. Originally they had a fully enclosed chain so nothing got in there. But a good full length chain guard on the top run of the chain would help heaps.
yamahaoemparts.com.au/partFinder/fiche/y...175/cylinder#content
22 Oct 2021 03:40 #7
22 Oct 2021 03:47 #8
