DT400B twin shock piston markings
- Jammyyammy
DT400B twin shock piston markings was created by Jammyyammy
Hi - do any of you knowledgeable people out there know what the markings on the top of my piston mean?
At the front, 8-4
At the rear, 8525
Is it standard bore and is it a standard Yamaha OEM piston?
Many thanks….
At the front, 8-4
At the rear, 8525
Many thanks….
Replied by MarkT on topic DT400B twin shock piston markings
Hard to say if it's OEM or quality aftermarket... what are the markings cast inside underneath? Might say YAMAHA or AZUMI or something like that.
Piston is first over in Yamaha-speak. 85.25 mm from the markings.
02 Oct 2021 08:10
- Jammyyammy
Replied by Jammyyammy on topic DT400B twin shock piston markings
Thanks for the info. It says ART on the side. Does that mean anything to anyone? I’m not planning on taking the piston off, so can’t check for markings on the underside of the crown as there is carbon build up and I don’t really want to disturb that.
02 Oct 2021 09:50
It's probably original Yamaha. Enduronut would know for sure. Casting marks underneath would be inside the skirt, not under the crown.
02 Oct 2021 11:06
- DEET
- Moderator
Replied by DEET on topic DT400B twin shock piston markings
Hmmmm.... except for the reed valve windows, it reminds me of a 4-stroke piston.
I only know certain pistons.... seeing windows in the sides around the wrist pin doesn't seem right for a DT400B.
If it has been running good, then it must not make a difference.
02 Oct 2021 13:27
Art is a piston manufacturer and did make Yamaha OEM pistons as well as aftermarket ones. OEM pistons often have a model code or other identifier cast inside the skirt
On ebay there are several OEM pistons for sale with the windows by the wrist pin... I've seen a 400 piston come apart where the crown broke off through the top of those window right below the "ledge". Allegedly the rider downshifted into a low gear at high speed and let out the clutch... tach pegged and piston let loose.
Anyway, here's one of the Yamaha pistons on ebay.
02 Oct 2021 14:11
- Enduronut
- Founder Moderator
Replied by Enduronut on topic DT400B twin shock piston markings
Yes . . . you have a stock Yamaha 1st oversize piston
There is no word "Yamaha" cast into the underside of piston on this particular model
. . . but you will find the numbers 50002 on the inner exhaust skirt.
02 Oct 2021 14:20
- DEET
- Moderator
It’s been a while since I’ve seen a DT400 piston.
I didn’t recognize the holes in the side.
02 Oct 2021 17:13
- Jammyyammy
50002 Correct !!!
03 Oct 2021 07:56
