1975 DT400 twin shock - exhaust nuts torque
- Jammyyammy
1975 DT400 twin shock - exhaust nuts torque was created by Jammyyammy
Hi, anybody know what torque the nuts should be where the exhaust bolts onto the cylinder block?
Many thanks…
Many thanks…
27 Aug 2021 13:53
- Jammyyammy
Replied by Jammyyammy on topic 1975 DT400 twin shock - exhaust nuts torque
…. in N.m or lbs.ft
27 Aug 2021 14:21
- adguy2112
Replied by adguy2112 on topic 1975 DT400 twin shock - exhaust nuts torque
See page 142 in the service manual section for that year bike. Torque specifications are by fastener size. I think a 13MM fastener was 15 ft lbs but probably best for you to verify.
27 Aug 2021 14:37
Replied by MarkT on topic 1975 DT400 twin shock - exhaust nuts torque
Caution!!!!
They are only 6mm! Stepped studs. Very commonly broken.
27 Aug 2021 18:00
- Pedalcrazy
Replied by Pedalcrazy on topic 1975 DT400 twin shock - exhaust nuts torque
Use a new gasket and snug them up until they feel tight...taking into consideration their size. I like that you want to use correct torque. I'm the same way. However, on non-critical parts like that I wing it a little as manuals likely don't call out that connection. Just tighten it until it breaks then back it off a little LOL.
28 Aug 2021 08:27
