Turn signal relay
- motorocsta
Turn signal relay was created by motorocsta
Does anyone have the part number for a 1975 DT175b turn signal relay? Do you know a vendor that has one?
Thanks in advance.
Thanks in advance.
20 Aug 2021 10:35
Replied by Gr8uncleal on topic Turn signal relay
If you want to rigidly stick to original equipment, then the part number is 438-83350-62 and I have attached a photo below. However, any style of 6v flasher relay will do the job, so long as the wattage of the indicator bulbs matches closely to the numbers on the side of the relay.
If you go for a modern relay, you only need the two pin type and the brown wire goes to the terminal marked X and the brown/white to that marked L.
20 Aug 2021 11:11
- spudmanDT250
Replied by spudmanDT250 on topic Turn signal relay
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=273949692188&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
