Bearing puller for crankshaft
  • tlh0824
  • tlh0824's Avatar Topic Author
Bearing puller for crankshaft was created by tlh0824
 Can anyone recommend a bearing puller so I can separate the old bearing from the crankshaft. I am on my second Amazon purchase, there is hardly and meat for a puller to grab on to.
Thank you
Last edit: 19 Aug 2021 16:26 by tlh0824.
19 Aug 2021 16:25 #1
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Replied by RT325 on topic Bearing puller for crankshaft
I use one the same as you pictured. I just have the bolts loose & fit it over the bearing & sit one side in the vice--poor old vice-- & smack the other side with a BIG hammer & never fails to drive it off or far enough off so that its almost to where the shaft steps down a few thou to then fall of.
Would be the bigger of the two pictured i use i guess, as only have one. Looks like a useful set to have.
Last edit: 19 Aug 2021 16:48 by RT325.
19 Aug 2021 16:45 #2
  • tlh0824
Replied by tlh0824 on topic Bearing puller for crankshaft
Ok, right now I cant get it around enough to get the bolts in. I plan to get longer bolts.
I always thought hammers and crankshafts were not friends!
19 Aug 2021 17:33 #3
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Ya not hammering the shaft as such, but the bearing tool. If you're using the bigger one in the pic they're pretty long bolts. I'll demo mine shortly if i can.
Had to improvise a bit as no crank handy. But imagine the bearing is on the shaft--as yours is--& there's a smidgen of gap behind the outer bearing. Then set the tool against/behind the bearing & will only just get there but taper will force its way in. Could pull it in with the bolts but really needs a short sharp jolt--shock treatment works for me. Pics i see aren't quite in order but imagine pic 6 just getting behind the edge while on the shaft, Your right side bearing i guess is still in the case which is normal as 'that side' is just a slide fit onto the crank & bolted up tight by the crank nut & gear.
Last edit: 19 Aug 2021 18:23 by RT325.
19 Aug 2021 17:50 #4
Replied by Pedalcrazy on topic Bearing puller for crankshaft
I was schooled by several expert mechanics and machinists on the heat/freeze method of installing and removing bearings from cranks and cases. It's amazing how it works. Different thing with yours is they are both already assembled. You might put the whole assembly in your freezer for at least 24 hours. Then use a propane torch on the outside of the bearing and keep the flame off the crank. Pry a little between bearing and crank and you might be surprised. You have to get the bearing hot before the crank gets hot. With heat/freeze I've had bearings litterly fall out of the side cases.
19 Aug 2021 18:11 #5
Replied by Top Jimmy on topic Bearing puller for crankshaft
Bearings like this are hard to remove in tact.  When you pull on the outer race it presses on the balls (try not to laugh) which press onto the inner race.  This causes the inner race to squeeze onto the shaft.  The more you pull, the tighter it squeezes.
My preferred method when all else fails is to remove it one piece at a time.  First step is to rip out the ball cage.  This requires a bit of brute force but its not that difficult.  Can be done with pry bars, picks, cold chisel, etc.  Once removed, move all the balls so they are on one side and you should be able to remove the outer race.  With the outer race removed, the balls just fall out.  Then you have to remove the inner race.  A Dremel tool or small die grinder with a cut off wheel is needed. Cut some slits in the inner race. At least two.  Go as deep as you can without cutting into the crankshaft.  Then a few light taps with a cold chisel should split the inner race and you are done.  If you don't have a grinder, another option is to heat the inner race and try to get it to slide off. A propane soldering torch will do the job.
Hope this helps.  Good luck.
19 Aug 2021 19:29 #6
Replied by MarkT on topic Bearing puller for crankshaft
The type RT325 has artfully demonstrated has always worked for me to remove a crank bearing stuck on crank.
Odd that your bolts are too short...  You can also tighten the bolts which will force the wedge in behind the bearing if you don't want to use the "BFH" method.
19 Aug 2021 20:02 #7
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Tomorrow, if i can find a complete crank, i'll do a video of my brutality. Never yet broken a bearing. Can see how possibly tightening the bolts might make it hold tighter on the shaft because of how the balls are getting squashed--trying not to think about that lol--. That's why i think the shock treatment with BFH is best--for me.
19 Aug 2021 23:08 #8
  • RT325
  • RT325's Avatar
  • Platinum Member
  • Platinum Member
Here's a video of the tool being used to remove the inner race.
The following user(s) Liked this Post: Rick C., Bdee
19 Aug 2021 23:22 #9
I often use the BFH method too...
...or you can use the correct method shown in video.
Bearing always comes right off with no heat or taking bearing apart.  The right tools make jobs easy and this is the right tool for this job.
20 Aug 2021 05:40 #10
