Fuel Tank "locating damper" location
- spudmanDT250
Fuel Tank "locating damper" location was created by spudmanDT250
Just a quick question. Can anybody tell me where part #8 (Locating Damper) in the attached diagram is located on a '75 DT250? I've had the tank off the frame a few times now, so I know the part is not there, but I'd like to know where exactly it goes if I decide to pick one up. It certainly looks like it would be some sort of rubber mount for the tank, but I don't see where it would "fit" based on its shape. Thanks!
18 Aug 2021 22:24
Replied by Gr8uncleal on topic Fuel Tank "locating damper" location
Right at the very bottom of the frame "spine". The main harness goes through it.
I'll post a photo shortly.
Edit - photo attached.
The following user(s) Liked this Post: Jack, Top Jimmy, spudmanDT250
- spudmanDT250
Replied by spudmanDT250 on topic Fuel Tank "locating damper" location
Awesome....thanks Gr8uncleal!
19 Aug 2021 07:55
- Schu
Replied by Schu on topic Fuel Tank "locating damper" location
You will probably see wear marks on your frame right where that damper used to be. The photo below is my DT250B and you can't miss the witness marks worn right thru the paint.
The following user(s) Liked this Post: MarkT, Jack, spudmanDT250
19 Aug 2021 09:17
- Pedalcrazy
Replied by Pedalcrazy on topic Fuel Tank "locating damper" location
Yep wear marks on bottom side of tank too.
The following user(s) Liked this Post: spudmanDT250
19 Aug 2021 18:23
Replied by MarkT on topic Fuel Tank "locating damper" location
Get a damper... or start planning for welding the rear tank mount and/or seam.
19 Aug 2021 19:45
- spudmanDT250
That's exactly what I was thinking, MarkT. Time to be a bit proactive.
19 Aug 2021 19:49
