Does anyone know the size and thread pitch for this nut?
- tlh0824
Does anyone know the size and thread pitch for this nut? was created by tlh0824
Hello
Does anyone know the size and thread pitch for the nut that bolts the gas tank down - 1975 DT250
Thank you
Thank you
18 Aug 2021 11:43
- KennyV
Replied by KennyV on topic Does anyone know the size and thread pitch for this nut?
It's a M10 x 1.25 on my 250A.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
21 CRF300l Rally
The following user(s) Liked this Post: Rick C., MarkT, Bigdog302
18 Aug 2021 11:52
- Sneezles61
Replied by Sneezles61 on topic Does anyone know the size and thread pitch for this nut?
I have to take metric bolts/screws down to the local hardware store and thread them on a nut to see what size it truly is... I'm learning... Then when I buy what I need, I double it... nice to have some on hand... in case you "mis-place one.. or many"...
Sneezles61
Sneezles61
18 Aug 2021 12:44
- Schu
Replied by Schu on topic Does anyone know the size and thread pitch for this nut?
And if you are also missing the large washer that goes under that nut and sits on top of the rubber insulator, you can use one of these special washers that are used on automotive shocks and struts. It is cupped like the original washer and works nicely as a replacement. Unless you are looking for exact OEM stuff.
The following user(s) Liked this Post: MarkT, tlh0824, Jack
- Rick C.
Replied by Rick C. on topic Does anyone know the size and thread pitch for this nut?
This is, " handier than pockets in yer underwear !! "
www.lowes.com/pd/IRWIN-Metric-Thread-Gau...fPD_BwE&gclsrc=aw.ds
The following user(s) Liked this Post: tlh0824
18 Aug 2021 16:31
Replied by RT325 on topic Does anyone know the size and thread pitch for this nut?
I would have thought 8mm x1.25. 10mm sounds a bit overkill to hold the tank down.
Might have to withdraw that statement as found a pic of a nut with that number & looks big. Even if it 'is' 10mm the thread will be 1.25 still.
Edit 3 haha. Didn't see KennyV post, so 10x1.25 it is then.
- Pedalcrazy
Replied by Pedalcrazy on topic Does anyone know the size and thread pitch for this nut?
You can see from the exploded view that the part number indicates M10.
18 Aug 2021 19:33
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=171567479032&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by MarkT on topic Does anyone know the size and thread pitch for this nut?
Here in the US when I was a kid it used to be... if you could find a metric nut anywhere but a dealership... the hardware store 10mm nut was 1.5 pitch too.
But there are so many Japanese products here now and even back then Datsun and Toyota used a 1.25 pitch for a 10mm nut. So I think it's actually harder to find a 10 x 1.5 nut here in the US than a 10 x 1.25. Yamaha definitely used 10 x 1.25.
Wrench sizes have varied too... a 17mm wrench size was common for 10mm but Japanese tended to use a 14mm hex size.
18 Aug 2021 21:10
- JGersh
Replied by JGersh on topic Does anyone know the size and thread pitch for this nut?
This is from the Yamaha Enduro Tool Guide… it’s supposed to cover all bolt sizes and thread pitch’s used on these bikes over the years.
2 - ‘68 DT1
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
‘12 Triumph Scrambler
‘70 RT1
‘70 CT1-B
2 - ‘70 HT-1’s
The following user(s) Liked this Post: MarkT, Mothersbaugh, JayB, Jack
