DT400 twin shock - RH crank seal
- Jammyyammy
DT400 twin shock - RH crank seal was created by Jammyyammy
Hi - I’ve replaced the LH crank seal and now due to not being able to find a slight leak when performing a leak down test, am planning to replace the RH crank seal.
I’ve never done that before.
Are there any good videos to watch before I attempt it?
Apart from the seal and gasket, is there anything else I should purchase before I start?
Also, should I do any other jobs while I’m “in there”? Replace any clutch parts for example (the clutch does seem quite ‘heavy’) that wear out.
I’ve not ridden the bike yet (still restoring it) so don’t know what actually ‘needs’ to be done.
Many thanks.
Many thanks.
17 Aug 2021 23:33
Replied by RT325 on topic DT400 twin shock - RH crank seal
Heavy clutch is more often that not the cable & you sure can't beat a new & lightly lubed cable.
18 Aug 2021 00:26
- Jammyyammy
Replied by Jammyyammy on topic DT400 twin shock - RH crank seal
Thanks. Yes, I bought a new cable, but have not yet fitted it.
18 Aug 2021 00:42
- Jammyyammy
Hi - does anyone know where I can buy genuine Yamaha crank seals (DT400 twin shock) in the UK?Also, when installing them, should I ‘grease’ the outside surface of the seal (where it mates with case)?
Thanks again….
Thanks again….
18 Aug 2021 14:16
- msavitt
Replied by msavitt on topic DT400 twin shock - RH crank seal
JammyYammy - hello from the colonies
My DT360 and DT1E both had an o-ring under the primary gear on the crank that you should replace while you have it apart, assuming your 400 has one.
When I had 360 apart I changed the clutch disks with a Barnett kevlar clutch kit because the disks looked crappy. On the DT1E the disks looked good and were at the top end of thickness spec so I reused and glad that I did. New clutch cables in both cases
good luck!
good luck!
18 Aug 2021 16:37
I grease all seals to fit them to help them slide in without damage. Others may disagree.
The following user(s) Liked this Post: Swoop56, Sneezles61, DT400FRANK
18 Aug 2021 16:48
- Swoop56
Replied by Swoop56 on topic DT400 twin shock - RH crank seal
Don't forget to apply some grease or vaseline between the inner and outer seal lips ,
( where the crankshaft will sit ) .
18 Aug 2021 17:56
- Wessi
Replied by Wessi on topic DT400 twin shock - RH crank seal
Crank seals should be available at your Yamaha Dealer.
19 Aug 2021 00:08
- Jammyyammy
Thanks to all.
I bought genuine Yamaha crank seals from tytrials in the UK.
They also include the O-ring (thanks also to Msavitt).
They also recommended greasing the outside of the seal (thanks also to RT325).
19 Aug 2021 05:54
- DT Tim
Replied by DT Tim on topic DT400 twin shock - RH crank seal
My clutch is so heavy it actually spoils the ride, I did replace the springs for new, can’t remember if HD or not, will have to check. Cable was free and smooth when not use but is old , so looking for a new one.
I would really sort it before finishing your build, I actually hold back from riding because it’s so heavy
21 Aug 2021 14:30
