Leak on underside of engine
  • Jagarrett369
  • Jagarrett369's Avatar Topic Author
Leak on underside of engine was created by Jagarrett369
Hi, I have a 1974 DT250. I have a pretty steady leak coming from where the clutch cable actuates a shifter shaft on the underside of the motor. What is the fix for this? Thanks to all in advance.
06 Jul 2021 12:42 #1
Replied by msavitt on topic Leak on underside of engine
Hello - just looked at Partzilla and your 250 has same mechanism as my 360.  Seal easy to replace and should help fix so long as the shaft is nice where seal rides and the needle bearing is good.  To minimize  the old guy dribbling oil I found that if you can fiddle with the adjuster to get the shaft in proper position to be pulled per manual while getting lever as flush with case as possible.  I went from a small slick on the ground to maybe a drop or two by doing this, and this was with a new shaft, bearing and seal and after also replacing the washer on the cam detent which is close by and could also be a dribble source.  Good luck with this!
07 Jul 2021 07:45 #2
Replied by Sneezles61 on topic Leak on underside of engine
I've a small pan, seems to keep the oil off the concrete!
... Someday... I'll follow along for now.
Sneezles61
07 Jul 2021 13:21 #3
