Back fires while trying to start
- Patroll330
Back fires while trying to start was created by Patroll330
My 1975 DT125 B 12volt system backfires when tring to start. Its like it starts up or it will backfire and won't start . The spark looks good but shuts off occasionally and hard to start back. Replaced the points, condenser, and new brushes for the 12 volt generator. Could the coil or does the 12 volt generator/starter system a CDI IGNITOR All help appreciated.
Replied by MarkT on topic Back fires while trying to start
Did you set the timing correctly?
03 Jul 2021 21:19
Replied by RT325 on topic Back fires while trying to start
Well, if it was a magneto system i'd be thinking the flywheel locating key had broken. Hold that thought as i guess it's still possible on an armature system. Have you had the armature off just prior to this happening. Is the advance points cam located in place. If the spark disappears occasionally then--don't know sorry.
04 Jul 2021 00:27
- Patroll330
Replied by Patroll330 on topic Back fires while trying to start
I own a 1975 DT125B American 12 volt/generator/starter no magneto.
04 Jul 2021 21:13
- Youngdrakeo
Replied by Youngdrakeo on topic Back fires while trying to start
My ct3 would do this if I switched the key on the 3rd position (lights)
Earth problem or bad coil.
New vape ignition sorted it..
73 CT3 modified, 74 AG175 MX, 79 YB100 x2 , 79 GT 80 ,2015 ducati scrambler ,honda CT70
The following user(s) Liked this Post: Patroll330
04 Jul 2021 22:20
