1974 DT125A Build/Restore
  • torqueflight
  • torqueflight's Avatar Topic Author
Replied by torqueflight on topic 1974 DT125A Build/Restore
Thanks RT, the next time I get to work on it, ill give that a shot. I might build a brace over the tire to take the flex out of them.
Also forgot to ask about if someone knows where to find a shift level for an E start bike. Mine came broke off and its been kinda hard to find one. Is ebay my only bet?
25 Apr 2021 21:48 #21
Replied by RT325 on topic 1974 DT125A Build/Restore
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=224047930502&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Just looking at images to get an idea of how much the gear lever steps out & this showed up looking like new--till you look in the tank top & little rust. Someone's been busy polishing.
www.mecum.com/lots/LV0120-391442/1974-yamaha-dt125a/
26 Apr 2021 01:40 #23
  • torqueflight
I think the shifter has a major bend to make it around the case.  Ill keep looking on ebay. If not ill try and make something custom.
Also the seat cover came in today. Might try and make the old seat padding work by adding a little foam layer on top of it.
Last edit: 26 Apr 2021 21:09 by torqueflight.
26 Apr 2021 21:08 #24
Replied by Rick C. on topic 1974 DT125A Build/Restore
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=154397472629&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Mothersbaugh on topic 1974 DT125A Build/Restore
On partzilla.com, look up 71 AT-1C, and you'll find it's still available for $35. Look at 74 DT125, and it's unavailable, but click on that part, and it says it was used for many 125's before 74. Go figure.
www.partzilla.com/catalog/yamaha/motorcycle/1971/at1c/shifter-2
www.partzilla.com/product/yamaha/173-181...039a2306806615ee4b3b
26 Apr 2021 21:31 #26
  • torqueflight
For sure more than I want to pay. If I cant find a fair price Ill just end up making one.
26 Apr 2021 22:38 #27
  • pabdt
  • pabdt's Avatar
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 DT125A Build/Restore
I believe you are safe on the fuel tank.  no tumblers in that lock.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 26 Apr 2021 22:46 by pabdt.
26 Apr 2021 22:43 #28
yep just get any old steel lever from the wreckers with the common spline & cut n weld. I used to run 5.5 inches, under 6, from center of footrest to center of gear lever tip. Done it many times with my arc welder. Wish i could weld alloy too.
26 Apr 2021 22:57 #29
  • torqueflight
I dont know how I missed this, we must have posted at the same time. Youre awesome, thanks so much. Will probably order this.
Last edit: 27 Apr 2021 05:07 by torqueflight.
27 Apr 2021 05:05 #30
